I need a dark Green
I need a dark Green
Post by Roadking41a on March 15th 2012, 11:12 pm
I went to Lowes and looked at Rustoleum Hunter Green. But it wasn't dark enough. Will painting a black base make it darker,or do I need to mix in some black to get the dark green I want? I need a green that is so dark that it looks black depending on the light.
Re: I need a dark Green
Post by Pierrel on March 16th 2012, 12:03 am
Im not 100% sure, but i don't think you get a different result from using a dark base. This used to be the case with older paint, but as i said i don't think so with rusto.
Your best option would be to custom tint it yourself, but i think its hard to get the right color. Hopefully some of the pros here will chime in Smile
Pierrel
Number of posts : 41
Job/hobbies : Student
Project : 1967 Mercury Cougar XR-7
Registration date : 2012-01-28
View user profile http://themercurycougar.blogspot.com/
Post by cac1967 on March 16th 2012, 12:12 am
Mix in black in small increment's until you get the desired color.
Post by Roadking41a on March 16th 2012, 12:16 am
Thanks. I will try it. I just read Ace hardware will custom mix paint. I am going to check it out tomorrow.
