Pearl/ Metallic spray job and clear coat
Post by wwwdotanthony on June 18th 2012, 8:17 pm
I know this has probably been asked a million times, but has anyone successfully done a pearl/ metallic job using topside etc.? I was thinking of buying topside and adding pearl/ metallic to it...
or
maybe trying this clear (has uv protection) and adding the pearl/ metallic to it if its not an arm & a leg.
http://www.minwax.com/wood-products/exterior-clear-protective-finishes/minwax-helmsman-spar-urethane
Its a urethane clear which should work with a polyurethane paint like topside?
Any advice is welcomed.
wwwdotanthony
Registration date : 2012-05-16
Re: Pearl/ Metallic spray job and clear coat
Post by retired plumber on June 20th 2012, 3:13 pm
I won't comment on the paint but I do know you can't add large metallics like metalflake and roll it. I have tried several times and it just won't work. Spraying is the ONLY way you can do that. You will also need at least 3 coats of clear with nothing in it so you can color sand and buff without getting into the metallic/pearl.
If the two type of paints are compatible with each other and can be cut with mineral spirits I would say go for it. Sounds pretty. Please post pictures and explain your process when you get done because this is an oft asked subject.
