going dark to light,should i primer?painting a VW bus
Post by chopperchuck on July 4th 2012, 11:34 pm
the VW bus is red W/white top & we're wanting to paint/roll on white from the belt line up to match,should i primer?i have roughed up the old paint & did some body work with a little bondo which i know i'll have to prime anyway,any thoughts on this?
we wanna go from this:
To something like this:
cheers
chopperchuck
Number of posts : 30
Job/hobbies : working on old junk--work for school dist #6
Project : 70 VW bus,48 Hudson,a few choppers
Registration date : 2012-07-03
Re: going dark to light,should i primer?painting a VW bus
Post by chopperchuck on July 5th 2012, 8:24 am
& would spray primer be OK to use?
chopperchuck
Post by 63Falconconvert on July 8th 2012, 9:03 pm
I always prime. Try the Rusto primer surfacer in quart or gallon cans. You can roll or spray it.
Post by chopperchuck on July 9th 2012, 12:39 am
Thank you again sir, how coats do you think it would take? 3-5? i'm already tired of sanding ahhh LOL-----chuck
chopperchuck
Post by retired plumber on July 10th 2012, 11:48 pm
All you need is enough to cover the red. I'm like 63falcon, I always primer. That gives a solid one color base to start on.
Post by chopperchuck on July 15th 2012, 8:29 pm
Ok,getting closer,still sanding nicks & dings out-there must be 10,000 small stone chips on the front mad3 ,try to feather/blend sand em flush..is a P.I.A! ahhh
how should i cut the prime 50/50?? huh and how many coats?
chopperchuck
