Help with roller marks!!
Post by minitruckin909 on July 29th 2012, 8:03 pm
im on a 4th coat and i still have roller marks i wet sanded with 1500 after the 1st two coats help asap! im using 3/4 cup m/s and 1 cup paint
minitruckin909
Registration date : 2012-07-29
Re: Help with roller marks!!
Post by minitruckin909 on July 29th 2012, 8:54 pm
minitruckin909
Post by 63Falconconvert on July 29th 2012, 9:05 pm
How bad are the roller marks? I would wet sand the 800 and keep rolling. Post a pic if you can.
Post by rick howe on September 12th 2012, 9:42 pm
i think your paint is still to thick i used 1 quart paint to 1 pint ppg med reducer to 1 pint of mineral spirits and the roller marks were gone on my 3ed coat. i also was still sanding with 400 on my 4th coat ; didn't use 1500 until my 7th coat
rick howe
Number of posts : 48
Project : 72 spitfire
Post by superdave on September 18th 2012, 9:54 pm
1500 is too fine for your initial coats. Start in the 400-600 range. You are going to have some roller marks, but if you thin it enough and roll it out smooth, it's manageable. The first 6 coats or so are just to build up thickness. 600 grit is fine to use. Once you get good coverage, then start worrying about the finish.
superdave
Post by 63Falconconvert on September 19th 2012, 8:08 am
Great advice......
