84 Chevrolet Truck C10 5.3 Swap'd - Metal Flaked ? Dark Blue
Re: 84 Chevrolet Truck C10 5.3 Swap'd - Metal Flaked ? Dark Blue
Post by AGearHead4Life on November 24th 2012, 6:06 pm
Ok, here are the pics from today after two thick coats last night. Coats 5 + 6.
AGearHead4Life
Number of posts : 55
Job/hobbies : Custom Cars, Guns, Computers
Project : 84 C10, 92 Camaro
Registration date : 2012-11-21
View user profile http://www.youtube.com/user/AGearHead4Life
Post by AGearHead4Life on November 24th 2012, 6:07 pm
A lot of those particles on the hood are just dust. I didnt really wipe it off before I took the photos.
I plan to do one more coat and the 1500 grit wet sand and polish.
AGearHead4Life
Post by AGearHead4Life on November 24th 2012, 6:10 pm
I have also uploaded another video of the above progress onto my youtube channel.
http://www.youtube.com/watch?v=OzyMVmt1ujk&list=PLN05l39jxcWDu9d0KY6lH5l_zOsb518kE&index=2
Last edited by AGearHead4Life on December 7th 2012, 3:36 pm; edited 1 time in total (Reason for editing : video link updated)
AGearHead4Life
Post by AGearHead4Life on November 25th 2012, 12:30 pm
Well I'm headed out to inspect the pain. It was very cold last night. I think I should probably let it sit until next weekend before sanding and adding another coat. Especially since I'll be driving this to work tomorrow morning. We'll see.
AGearHead4Life
Post by AGearHead4Life on November 26th 2012, 1:10 am
A couple more photos today. The sun was bright. At the right angle you can see the aluminum/metal flake.
I'm still letting that 6th coat and all the rest under it set. I figure they could use some time to set in this cold.
AGearHead4Life
Post by AGearHead4Life on November 26th 2012, 1:11 am
I also spent two hours this evening sanding the LS Fest off the sides and rear of my truck.
AGearHead4Life
Post by 63Falconconvert on November 27th 2012, 11:25 am
Did you notice any change in the metalic when you wet sanded?
Number of posts : 1258
Post by AGearHead4Life on November 27th 2012, 1:46 pm
63Falconconvert wrote:Did you notice any change in the metalic when you wet sanded?
I did not, but I also wasnt looking for it. I just wet sanded, dried and rolled. Didnt inspect closely.
To me though the flake is not real noticable until hit with light like in the last pics I posted. When not in direct sun light it looks a lot different. But I also havent done any sanding since the last coat in the pics above.
I will sand this weekend and apply the last coat. Once it sets for a month or so I will final sand and polish. I think then I would have your answer for you on how the flake effected it. But remember, I have no painting experience before this. So I may not be answering your question correctly.
AGearHead4Life
Post by 63Falconconvert on November 27th 2012, 1:53 pm
You answered it perfect so far and I think you understand my question.
Your work so far looks great, you will have awesome results in the end. Keep us posted thumbs up
Post by AGearHead4Life on November 27th 2012, 2:58 pm
63Falconconvert wrote:You answered it perfect so far and I think you understand my question.
Thank you Much!
I will keep the updates flowing.
AGearHead4Life
Post by JWP on November 27th 2012, 3:33 pm
That is an in interesting approach there. I'm curious to see how the rest of the truck looks.
In response to your comments about finding dents, you can use what is called a guide coat. Typically this is a dusting of a contrasting color over primer. You sand the surface and anywhere the guide coat is left is a low area, and consequently the areas that sand down the quickest are your high areas.
Notice the black paint over the yellow primer, when done sanding the low spots will be indicated by the black paint/guide coat that remains.
JWP
Registration date : 2012-11-05
Post by AGearHead4Life on November 27th 2012, 3:39 pm
JWP wrote:In response to your comments about finding dents, you can use what is called a guide coat. Typically this is a dusting of a contrasting color over primer. You sand the surface and anywhere the guide coat is left is a low area, and consequently the areas that sand down the quickest are your high areas.
Alright, great.
So, when a low spot is found just simply fill with bondo and wipe even? Or do I have to sand down to metal? And on high spots I tap it down with a hammer then check if i tapped it too far and then fill if so?
AGearHead4Life
Post by JWP on November 27th 2012, 3:42 pm
AGearHead4Life wrote:
JWP wrote:That is an in interesting approach there. I'm curious to see how the rest of the truck looks.
Alright, great.
Well it depends on the nature of the problem, but I would probably lean towards filling it with bondo or something similar and sanding it smooth. Metal has a funny way of bending some times and different dents may require different techniques.
JWP
Post by 63Falconconvert on November 27th 2012, 3:54 pm
If the panel is "dented" then fill it with Bondo or hammer it out. If your panel is "wavey" then load the panel with primer and block it straight.
I know this is a lot to take in and a lot to try to explain. Go to my 63 Falcon under projects and loot at some of my body work pics and look on You Tube for block sanding videos.
Hope this helps.
Bob
Post by 63Falconconvert on November 27th 2012, 4:02 pm
http://rolledon.forummotion.com/t694-68-mustang-coupe
http://rolledon.forummotion.com/t747-1963-ford-falcon
http://rolledon.forummotion.com/t420-1976-mustang-cobra
In my opinion these are the 3 best projects to look at for following a project from start to finish. Everything from welding to body repair, block sanding, painting, polishing etc.
There are many great paint jobs on this forum, look through them, ask questions.
Post by JWP on November 27th 2012, 4:03 pm
63Falconconvert wrote:If the panel is "dented" then fill it with Bondo or hammer it out. If your panel is "wavey" then load the panel with primer and block it straight.
Hope this helps.
Bob
Bob your answer was way better than mine.
AGearHead4Life - I've heard the Eastwood videos on this topic are pretty good as well.
JWP
Post by AGearHead4Life on November 27th 2012, 5:31 pm
I thank you Bob and JWP very much for taking the time to post a reply on this thread. It is very helpful and when I get home I will hopefully have time to do as you've instructed and review the three other projects that you posted. I've looked through some of the projects but was more focused of the outcome at the time. Now I'll go back and learn something.
AGearHead4Life
Post by cac1967 on November 27th 2012, 6:49 pm
Bob is spot on about fixing the small dent's and wavy panel's thumbs up
Post by AGearHead4Life on December 6th 2012, 5:58 pm
Alright, here's the update video. I made a boo boo..
http://www.youtube.com/watch?v=pJX7o7b0LXw
Here's a link to the whole playlist:
http://www.youtube.com/playlist?list=PLN05l39jxcWDu9d0KY6lH5l_zOsb518kE
AGearHead4Life
Post by JWP on December 7th 2012, 9:15 am
Do you think the issue was the fact that you let the paint sit in the jar for too long?
Either way, thanks for sharing the ups and downs.
JWP
Post by AGearHead4Life on December 7th 2012, 11:44 am
JWP wrote:Do you think the issue was the fact that you let the paint sit in the jar for too long?
Yes, It was close to the same time as I had done for all the previous coats, but this time it was a little warming outside. MS must have evaporated. I should have just test the paint before applying it. I probably could have just added more MS to it to fix the problem.
I hope to fix my mistake this weekend.
AGearHead4Life
Post by AGearHead4Life on December 14th 2012, 2:01 am
I hope to get an update video up soon with the final coat. I havent final sanded it and polished yet though.
Here are a couple pics of it the day I rolled the last coat on.
AGearHead4Life
Post by AGearHead4Life on December 14th 2012, 2:04 am
Also, Thought I'd let yall know this truck is in this months issue of GM High Tech Magazine on page 29 in the LS Fest coverage.
AGearHead4Life
Post by cac1967 on December 14th 2012, 1:59 pm
lookin good man!!! congrat's on the magazine photo and keep up the great work!!!!!!
Post by AGearHead4Life on December 15th 2012, 11:04 am
cac1967 wrote:lookin good man!!! congrat's on the magazine photo and keep up the great work!!!!!!
Thank you Sir!
I'm trying to guestimate how long is long enough to let this paint cure before doing the final sand and buff. I've heard people say they waited a month in warmer temps. So far I'm planning to just wait a month.
Any suggestions?
AGearHead4Life
Post by Sponsored content Today at 12:27 am
