I used the wrong roller, can i save the coats i already did?
Post by bradlee_moneyhun1997 on December 15th 2012, 3:45 pm
Hey well im a new member and i used the wrong roller (high density hiar type roller instead of foam) and im getting the rite ones now but can i save the coats of paint i have already done or could i just wetsand the current coats with 650 then start with foam roller from there on, or do i need to sand with like 200grit non wet paper? Thanx
Registration date : 2012-12-15
Re: I used the wrong roller, can i save the coats i already did?
Post by 63Falconconvert on December 15th 2012, 10:40 pm
The question is how much orange peel do you have. If you have little then 600 or 800 grit is good. If you have a lot of op then I would use 400. Anything courser will gouge your paint and then you will not be happy in the end. Remember your building thickness, your final sand will get you flatness. Hope this helps.
Post by bradlee_moneyhun1997 on December 16th 2012, 1:34 am
i dont have to much so im just going to try 650 wet then start from there with 2 coats, wet with 800 then 2 coats, and final sand with wet 1500, but then do i polish it or buff first, and if polish can i apply by hand then just buy a buffer and it will be done? Thanx and those are my only ?
Post by 63Falconconvert on December 16th 2012, 8:00 am
Once you're done wet sanding then you will "cut" your paint. What this means is that you will use a buffer with a cutting pad, cutting compound. This will get rid of fine scratches and bring up the shine. Next you will "buff or polish" the car using your buffer a polishing pad and polishing compound. This will really bring out the shine. You will never do it by hand. This paint is just to soft to hand rub. Check out my 63 falcon in the project section. This will give you step by step help.
What kind of car are you painting?
Post by retired plumber on December 24th 2012, 5:03 pm
Listen to 63falconconvert. He knows what he is talking about as you will see when you check out his car.
