majic enamel paint
majic enamel paint
Post by firehawk on January 14th 2014, 5:42 pm
Has anyone used majic enamel paint from the tractor supply store?
I just bought some majic primer and tried to mix it with pant thinner from wal mart (green brand). it did not mix well it kept separating. I then tried to mix it with acetone (green brand) also from wal mart.This didn't work either. I guess I will have to buy the majic brand paint thinner like the directions say. I just assumed it would work since everyone is mixing rustoleum this way. I was also wondering if I could roll rustoleum over the majic primer after it is fully dried and wet sanded. Would it have a bad reaction? Or will it be fine since they are both oil based enamel? Thanks for any help.
firehawk
Registration date : 2014-01-13
Re: majic enamel paint
Post by firehawk on January 14th 2014, 5:46 pm
I decided to test the majic primer on my trunk deck lid with no thinner. It covered well with one coat but has bad orange peel. I will try to wet sand it flat with 400 grit and see what happens. I will post before and after pictures when its done.
firehawk
