Rattle Can Under Roll On
Post by hkestes on May 22nd 2014, 12:54 pm
Did a search but could not find an answer.
I have a 48 Plymouth Coupe that needs paint. With all the rounded surfaces, drip rails, window surrounds and tight spots my question is can I use rusto rattle cans first to get in those spots as a base and then roll over the rattle can paint? If it will work, it would be much quicker and give me a much better build in those tight spots. Here is what I am working on and it looks much better in the photos than in person.
hkestes
Registration date : 2014-05-22
Re: Rattle Can Under Roll On
Post by cac1967 on May 22nd 2014, 10:57 pm
Yes it will most likely work, just make sure you paints are a match on a test panel, different batches may vary somewhat in color.
