Adding Metal Flake to the Paint
Post by Dave74 on December 10th 2007, 12:08 pm
it's long been an unchallenged fact in the Paint On A Budget practice that you can't add metal flake or get a metallic finish on the acrylic enamel. I found this somewhat limiting and a nice challenge. So, I started experimenting on the Satellite hood which is being replaced by a Roadrunner bulge hood. So far, here's what I'm finding out (Pics will be posted later).
materials
Base paint
odorless mineral spirits
2 paint trays/ with high density roller each
.004 micronic metal flake
Starfire Acrylic Enamel Clearcoat.
an old spice/pepper can
a clean metal putty knife
Cost for the extra stuff:
.004 micronic metal flake: varies, I use flakes from http://www.paintwithpearl.com/flakestore.htm
and a four oz jar costs from 12.99 on up.
Starfire Acrylic Enamel Clearcoat: about forty bucks per gallon (more than you'll need)
odorless mineral spirits works well as a reducer for this clearcoat
http://www.paintforcars.com/clearcoats_aecc2.html
The following steps that I'm adding will be an addendum to the methods posted here, you simply get to the point where you've polished the final layer of paint and remove the swirls, getting it to the glassy gloss you want.
1. The next step is to clean the car with a mild dish detergent like Dawn liquid and water to remove any residue from the polish.
2, Wipe it down with a lint free towel (cloth diapers work well) dampened with mineral spirits.
3. Have your paint tray loaded up with a paint/mineral spirit mixture. Use the ratio you've been using, for me, it's 50/50.
4. Have another empty paint tray ready with a four inch high density foam roller, the spice/pepper can loaded up with the flakes, and the putty knife at the ready.
5. Horizontal areas: hoods, trunks, etc. begin by adding another layer of basepaint/mineral spirits to a section. I find that the crosshatching method of roller painting the best for this stage, it eliminates the tiger striping so many people have talked about. Crosshatching is simply painting in criss cros patterns, instead of vertical or horizontal alone. It's kind of like painting in the motion of a z pattern. Again, very light pressure, only the weight of the roller.
6. with your off hand, take the spice shaker and start lightly sprinkling the micro flake onto the new layer while it's wet. i usually hold it about 7 to ten inches off of the surface. it doesn't take much and if you do get large blotches, don't worry, it happens and it's easily remedied.
7. take the clean foam roller and again lightly roll the wet area with flakes in a crosshatch pattern. Should you get splotches, simply roll in that area a little longer and the flakes will easily disperse. It's okay, and necessary, that the new clean roller pick up some of the micro flakes.
8. Check the area for a relatively even dispersal of flakes, and repeat the process until you've finished with the area.
9. I like to take the clean roller that's now holding a lot of flakes, and crosshatch the entire panel again while wet, especially on any of the vertical areas. This acts as a little more leveling for the flakes.
10. Let dry like any layer, but don't wet sand when dry. The self leveling nature of this method actually helps with the flakes dispersing and settling.
11, Wait 18 to 24 hours, then mix up a batch of the clear coat with the same ratio you've been using on the paint, blow out the bubbles, and let dry. Wet sand if needed, polish for a gloss.
For verical areas, the clean roller helps a lot with the application of the flake, but the shaker has to be used with the putty knife. Shake a little flake onto the knife, then gently blow the flakes onto the vertical plane. Go back over it with the roller brush to disperse, and that's about it.
Dave74
Number of posts: 26
Registration date: 2007-12-08
Re: Adding Metal Flake to the Paint
Post by Matt on December 10th 2007, 12:12 pm
Awesome man. Thanks for your contribution, this is exactly what we need. Hope to see more people with your initiative join the forums! I moved it to the tech section, seemed to fit better there.
:: Matt, Administrator
Number of posts: 563
Project: Ford Ranger Splash
Post by Dave74 on December 10th 2007, 12:24 pm
I'll post pics as soon as my daughter gets home from high school. I can't figure out how to turn her **** digital camera on! Embarassed
Dave74
Number of posts: 26
Post by MR_Se7en on December 11th 2007, 6:17 am
hot dang
cant wait to see this.
MR_Se7en
Number of posts: 9
Registration date: 2007-12-10
Post by 69cam on December 11th 2007, 8:37 am
I feel your pain on the camera thing. Smile
Does the clear have more of a shine than the base coat does?
Kevin
69cam
Number of posts: 2
Registration date: 2007-12-11
Post by Dave74 on December 11th 2007, 12:06 pm
yes, it adds a lot of depth to the paint. I'm actually thinking of seeing how the roller method works with adding a candy to the clear. . ..
If it works, it should go something like this
1. Basecoat
2. Intermediate coat: final basecoat layer with flake (or two, the thinning with Mineral Spirits actually allows you to add another coat)
3. clearcoat over the metal flake
4. candy clear.
I do know that you can add another layer or two with the metal flake in the basecoat/fllake. From what I see, it adds a bit more depth to the flake and it's self leveling so that helps. As long as you get that final basecoat without flakes pretty glossy and scratch/swirl free, there's no need to even wetsand the intermediate coats with flake. The flakes are a good effect with this.
Dave74
Number of posts: 26
Post by mazdawg78 on December 15th 2007, 11:59 pm
any more on this? pics? vids?
mazdawg78
Number of posts: 71
Registration date: 2007-12-15
Post by dumkopf on December 16th 2007, 6:48 pm
What about mixing the metallic flake in with the basecoat?
dumkopf
Number of posts: 11
Registration date: 2007-12-16
Post by Dave74 on December 17th 2007, 11:20 am
I've actually tested the metallic flake in the basecoat. If it's the final layer of paint you roll, it actually does work well. I used a fifty fifty ratio paint to thinner, added a tablespoon of micro flake, .004 micronic, the smallest flake in my color, and it leveled out well and you can see the flake. I still had to use a pepper shaker to help get an even distribution of the flake, but not as much as you'd think.
You can't sand this stage since it'll take the color of the flake down to the silver of the aluminum, but the flake actually does help hide any imperfections--I haven't had any yet--and it looks **** good. You will need an acrylic enamel clear coat over this so you can buff the shine into the surface.
I know, post the pics. I'm catching up on the bulge hood (I only bought a quart of paint and I've got the trunk, hood, and rear of the car finished) and will post the pics of the different layers and post a vid that shows the flakes the way they sit on the hood and trunk lid. It's Christmas, it's snowing, and I've been busy as heck.
Dave74
Number of posts: 26
Post by Matt on December 17th 2007, 11:26 am
What if you used a higher volume of mineral spirits to add more transparency to the coat, then added in metal flake to the batch. Would this allow depth and still let the color shine through? You could even go back over that coat with the same ratio without the metal flake and wetsand/buff to a shine. I would think that would make the metal flake appear deep in the paint. Just curious if that would work.
Post by Dave74 on December 17th 2007, 11:46 am
I did a test batch in black basecoat (fifty/fifty) and added emerald green flakes a few weeks ago. The green flakes are very easy to see even at this ratio, so thinning it more couldn't hurt.
Dave74
Number of posts: 26
Post by Matt on December 17th 2007, 12:01 pm
Cool. Do you have any pictures of your experiments?
Post by Dave74 on December 17th 2007, 12:22 pm
Matt wrote:Cool. Do you have any pictures of your experiments?
Yes, I'll post as soon as my daughter gets home. . .it's her camera. cyclops
Dave74
Number of posts: 26
Post by Matt on December 17th 2007, 1:18 pm
ha comp
Post by mazdawg78 on December 25th 2007, 8:04 pm
PICS PICS PICS!!!!!!!!!!!!!!!!!! nag Very Happy
mazdawg78
Number of posts: 71
Post by 94honda on January 2nd 2008, 3:05 pm
Oh my word..I am so excited...I cannot wait to try this!!!!
94honda
Number of posts: 6
Job/hobbies: Student..PoliScience Major
Registration date: 2008-01-01
Post by LesS is more on January 3rd 2008, 3:37 am
sounds like a cool idea, is it possible to mix it with the paint in the can or do you have to roll it on after? and pics plz Very Happy
LesS is more
Number of posts: 14
Registration date: 2007-12-30
Post by 94honda on January 4th 2008, 3:50 pm
if this is possible..maybe a pearl finish is not to far away.. sculpt
94honda
Number of posts: 6
Post by Matt on January 5th 2008, 3:45 am
94honda wrote:if this is possible..maybe a pearl finish is not to far away.. sculpt
or candy mmm
Post by mazdawg78 on January 5th 2008, 8:42 pm
candy would definitely tiger stripe i think. its a pain in the a$$ to spray and not stripe it
mazdawg78
Number of posts: 71
Post by megaglow_z on January 24th 2008, 1:29 am
Pics Already!!!!!!!!!!!!
I just got a 81 Toyota pu with a REALY nice body on it.
I need to see how this looks as i want to paint it a bright blue w silver metal flake.or a satan blue.cant decide.
Number of posts: 261
Job/hobbies: Autoglass tech
Project: 81 Yota
Post by 98ls1ttop on January 31st 2008, 12:29 pm
i would love to see the results of someone who has tried this.....very anxious....
98ls1ttop
Number of posts: 10
Registration date: 2008-01-30
Post by bob84 on January 31st 2008, 9:26 pm
Dave, pics of the metal flake....
Please !!! elephant
bob84
Number of posts: 49
Project: 1984 corvette
Registration date: 2007-12-09
Post by Matt on February 1st 2008, 1:46 pm
Dave hasn't been online since Christmas. Someone else might have to experiment with it a little and post their results.
Post by Squire Cobra Jet on February 13th 2010, 1:36 am
I have been reading through many threads and I found this posting which I thought should be added to this thread.
Dave74 wrote:The one knock against spraying are the city codes, some of us can't spray a car in their garage without getting a hefty fine for doing so in a residential area. The Iso's in the atomizers and hardeners are carcinogenic, and problematic. Rolling solves that problem and Rustoleum and the Brightside don't have iso's, so you're protecting your health as well.
It takes a lot of sanding, and some do overs, but it is well worth it. I'm finally getting mine finished...(after five years of.....medical bills, college tuition, and an ever diminishing budget). Rolled on is a source of pride.
Although I never got the metal flake to work right...thought I had it, but noooooooo...... never worked.
Number of posts: 181
Registration date: 2009-12-02
