satin finish
satin finish
Post by megaglow_z on January 24th 2008, 1:54 am
Ok,just acquired a very clean 81 Toyota p/u and the paint shows its age.
Its going to be my project truck so i can leave my 2000 s-10 alone like the wife says i should..lol huh
I'm wanting to get a finish like the hotrod flatz paints.is that doable with this line of paints?
something like this color/finish.... http://www.tcpglobal.com/kustomshop/hrf220.aspx
Ill post pics of the truck in the project section when i pick it up Friday.
There is one spot on the rear corner of the bed that will need a little filler.
Do you guys primer at all on this? it will be spring before i do the actual paint,but i will be shaving the handles and tailgate.so i will need to cover up my work till then.
I don't have a spray gun so i cant do an automotive primer.cant i use a rustoleum primer on the spots?
Number of posts: 261
Job/hobbies: Autoglass tech
Project: 81 Yota
Registration date: 2007-12-11
Re: satin finish
Post by JamesScudder on January 24th 2008, 7:51 am
You can get spray can primers, you would something that has a flexing agent in it for reliability really, over here in England, there is a company called U-Pol that do a fantastic rattlecan primer!
JamesScudder
Number of posts: 23
Registration date: 2008-01-21
Re: satin finish
Post by megaglow_z on January 25th 2008, 8:12 pm
Anyone know if i can get that kind of look with any of the roll on paints?
any color????
Project: 81 Yota
Re: satin finish
Post by Roadking41a on January 25th 2008, 8:16 pm
Would semi gloss work? I know Rustoluem has it.
Number of posts: 300
Project: undecided
Registration date: 2008-01-06
Re: satin finish
Post by btldigger on January 25th 2008, 8:30 pm
What if you just do the final wetsand then dont buff it. That would be pretty flat looking
btldigger
Number of posts: 61
Registration date: 2007-12-17
Re: satin finish
Post by megaglow_z on January 25th 2008, 8:41 pm
Roadking41a wrote:Would semi gloss work? I know Rustoluem has it.
hmm,that might be good.
btldigger
btldigger wrote:What if you just do the final wetsand then dont buff it. That would be pretty flat looking
I dont know if i would be able to get the smooth,satin, even look i want.
Its going to be a slammed minitruck.
Project: 81 Yota
Re: satin finish
Post by pinoyxpryde on January 25th 2008, 8:59 pm
check my thread in the projects section for semi-gloss rustoleum. its what im using right now
pinoyxpryde
Number of posts: 32
Registration date: 2008-01-25
Re: satin finish
Post by megaglow_z on January 26th 2008, 11:07 pm
pinoyxpryde wrote:check my thread in the projects section for semi-gloss rustoleum. its what im using right now
thats cool!
Now to just get it past the wife....she wants it gloss red.
Project: 81 Yota
Re: satin finish
Post by Matt on January 27th 2008, 12:21 am
Yeah man a semi-gloss would work well if you can find it in the color you want. Btldigger had a good idea as well. Before I buffed my truck it looked like it was sprayed hot rod flat yellow. I almost left it that way but went ahead and buffed for the gloss. Keep us updated, good luck!
:: Matt, Administrator
Number of posts: 563
Project: Ford Ranger Splash
Registration date: 2007-12-08
Re: satin finish
Post by badbyrdkoncepts on January 27th 2008, 8:57 am
hey this is not my car but i found it on the web, this guy used the satin black and it is a sexy color to me. i like it!!!!!!!!!!!!!!!
badbyrdkoncepts
Number of posts: 109
Registration date: 2007-12-18
Re: satin finish
Post by mazdawg78 on January 27th 2008, 12:27 pm
is that the mustang from mopar board? if so he said it was easier than gloss
mazdawg78
Number of posts: 71
Registration date: 2007-12-15
Re: satin finish
Post by mazdawg78 on January 27th 2008, 12:28 pm
also if you wetsand and not buff out it will still have a "shine" to it but look dull and faded. and rattle can primer fades bad
mazdawg78
Number of posts: 71
Re: satin finish
Post by Matt on January 27th 2008, 2:40 pm
Man that mustang is sick. I really like the way that turned out.
Re: satin finish
Post by ShelbyDodgeImp on April 30th 2009, 2:03 pm
I have been having good luck so far with satin black, I am not sure what other colors they make in satin- I know its extremely hard to get satin-anything from rustoleum around here without special ordering it.
There is only one place in my zip code that had satin black on the shelf, and they only had them in quart sized cans (no pints or gallons). It cost me more than what the paintjob did in driving store to store all weekend trying to find satin black.
But if you're doing satin, why would you want to ruin it by turning it into a flat texture? They make flat rustoleums, I would try that first- just remember not to wet sand the final coat, do lil if any polishing, and it should be ok. The hard part would be getting a final coat put down without any mistakes (no runs, minimal orange peel) as there is no margin of error in something you can't wet sand.
The other thing I would look into is seeing if you can find a flat or satin CC. I know in woodworking they make clear lacquer in flat, satin, semi gloss, and gloss. But how well would that hold up to road salt, UV and all the other things you expose a daily driver to? I really have no idea. I have two cases of satin clear acrylic but I am afraid to use it since my paintjob came out so good (so far) and I don't have a test piece (my test piece WAS the car lol). Probably wouldn't hurt to take a spare part like a trunk,hood, door- paint it as you plan to, try various CC's on it, and then let it sit out doors and watch to see what happens to it. Wouldn't show how road-salt resistant it is, but it would let you know if the UV from the sun will damage it, or the polluted rainfall.
You wouldn't have to CC right after your final BC, you'd just have to remove any dirt, wax, or oils from the surfaces before you apply a CC. So you could let your test piece sit for years before deciding to try a CC on your actual car.
IF you can get a CC to work, a flat CC might take some of the shine away from a satin paint job. The key I think would be in not wet sanding that color coat because it would ruin the texture (flat and satin paints have a texture, and will look like crud if you use aggressive abrasives on them).
I know that, with Antique Radios- people often use rustoleum's to paint on the trim parts on wooden radios in restoring them. Usually what they did from the factory is apply toner lacquer with a gun (basically lacquer with dyes and stains added to it so it looks walnut or mahogeny color), then they'd paint trim parts (like the sides of the speaker grill) with a flat oil based black, and then clear coat the whole thing with a satin or semigloss lacquer. I have had no problems with clear lacquer or toner lacquer "sticking" to wooden trim parts painted with brown or black rustoleum... but we're talking about furniture that sits inside 24/7, never sees UV light, and never sees polluted rain, road salt, or sand/dirt from roadways.
This set is toner-mahogonry lacquer, flat black rustoleum on the trim, followed by satin clear acrylic/lacquer:
It's shinny but not mirror-reflective.
ShelbyDodgeImp
Number of posts: 10
Job/hobbies: Perpetual Student
Project: 1992 Dodge Imperial Concept
Registration date: 2009-04-29
View user profile http://www.cardomain.com/ride/3072884
