Flash time?
Flash time?
Post by pinoyxpryde on January 29th 2008, 5:43 am
what kinda flash time does everyone use between coats when doing 2 coats in a day?
pinoyxpryde
Number of posts : 32
Re: Flash time?
Post by mazdawg78 on January 29th 2008, 2:20 pm
when i tried rollin i did one coat in the mornin and then one in the evening late. about 12-14 hours.
mazdawg78
Number of posts : 71
Re: Flash time?
Post by Matt on January 29th 2008, 2:54 pm
I did a recoat in 8 hours on my truck. Keep in mind it was during the fall at 75 or so degrees when I did it. I painted the first coat then waited 8 hours and painted the second coat. I then waited a full 24 hours before wetsanding and applying the next coat and so on and so on. It should say on the back of the can the optimal cure times per temperature.
Re: Flash time?
Post by JMJ Rick on January 29th 2008, 3:05 pm
I did one coat a day, the shortest amount of time was about 12 hours between coats but usually about 18 hours. Weather and humidity affect the dry time, as does adding mineral spirits. My first coat took 24 hours before I could recoat, I thought I screwed up and would be painting every other day, but the rest of the coats were fine to recover after about 12 hours. I painted in the cold garage with a tiny space heater, about 50 degrees indoor, 30 outside.
JMJ Rick
Number of posts : 114
Job/hobbies : Printshop owner
Re: Flash time?
Post by Matt on January 29th 2008, 5:58 pm
Well the good thing about the lengthy cure times is that you don't get burn out on the project Wink
Re: Flash time?
