Wetsanding
Wetsanding
Post by Matt on December 11th 2007, 11:48 am
You have to wetsand after every other coat to keep the finish smooth, give the paint something to adhere to, and reduce orange peel. During my project I picked up a few techniques that may be helpful to you. If you put a few squirts of dishwashing liquid in with your wetsanding water it will allow the paper to slide easier across the panel. Using just water to wetsand on fresh paint will sometimes form a suction and stick to the panel. This gets pretty frustrating when your trying to hold onto the paper whether by hand or sanding block. If your having these symptoms, try the dishwashing liquid it helped me out. Also I found that if you wetsand lightly enough to where water doesnt bead up on the panel any longer then it's a good time to move on. For example as soon as you spray water on the freshly dried paint it will bead up like it's been waxed really well. Use plenty of water and lightly sand the panel until when you spray water on it again that section doesn't bead up and roll off. Not sure if this applies to normal paintjobs but it worked great for me. Doing it this way also helped me see the places I missed (beaded up area) so I could go back and hit it again. Hope this helps!
Re: Wetsanding
Post by Dave74 on December 11th 2007, 1:14 pm
I find that you can wetsand well by learning how the sanding block/sponge moves across the surface. I sand in the same direction and when you first start (with only the weight of the sanding block) you'll feel it grab as you move through the sanding motion. Continue sanding in one place until the grabbing stops and the black moves over the surface like it's sliding on ice.
It doesn't take long to get the feel down! And I agree, Dawn works wonders!
Dave74
Number of posts : 26
Re: Wetsanding
Post by Matt on December 11th 2007, 4:32 pm
Yeah that's what I was talking about. Like it forms a suction underneath the sandpaper and causes it to grip up. You can also hear the sound of the way the sandpaper glides across the surface. When you first start it will sound like rubbing your hand on a piece of paper. Once it's smooth the sound goes away.
Re: Wetsanding
Post by FamilyForce6 on July 11th 2011, 5:57 pm
Matt wrote:Yeah that's what I was talking about. Like it forms a suction underneath the sandpaper and causes it to grip up. You can also hear the sound of the way the sandpaper glides across the surface. When you first start it will sound like rubbing your hand on a piece of paper. Once it's smooth the sound goes away.
Matt, what size did you cut your paper for hand sanding? Did you fold it in 1/2? I used dishsoap and it was helpful. I'll have to try the water spray to see what parts I missed.
Sean
FamilyForce6
Number of posts : 8
Registration date : 2011-07-02
Re: Wetsanding
Post by retired plumber on July 11th 2011, 10:24 pm
I'm not Matt but I fold mine in 1/4s and I always use dishsoap. You can also tell by the "drag" you feel as to how well its cutting. I can't really explain it very well but You will know what I am talking about after you have done 1/2 a panel. LOL
Re: Wetsanding
Post by cac1967 on July 11th 2011, 10:34 pm
X2,Mike is right on the money,I use the same method!!!
Re: Wetsanding
