Spray Gun.
Spray Gun.
Post by Roadking41a on April 26th 2008, 9:07 pm
I know most everyone has a HLVP spray gun but will a old siphon gun will work with a 1.4mm tip?
Re: Spray Gun.
Post by megaglow_z on April 27th 2008, 12:01 am
Dont see why not. you might have to test a few ratios to get the right mix.
got anything to test spray?
Re: Spray Gun.
Post by retired plumber on April 27th 2008, 1:56 am
Sure . That will work fine as long as your compressor will put out enough air. Most of those style guns need at least 50psi for a solid color and 65psi for metallic but that depends on the type of paint. Read the can, lower pressures will work but you will get orange peel. I have an old Binks with that size tip and my compressor puts out 8cfm and works good.
Re: Spray Gun.
Post by Roadking41a on April 27th 2008, 6:19 pm
Thanks guys I'll go get a filter for it I have a old hood to practice with.
Re: Spray Gun.
