What does everyone do with their rollers between coats?
Rolled On Forums :: Rolled On Forums :: Exterior :: Cleanup
Page 1 of 1 • Share •
What are you guys doing with your rollers between coats? I'm going to do a test panel first to get the technique down, and I don't want to use a new roller for every test coat. My test Panel is going to be a spare targa roof that I have for the corvette; its about 2 X 4 so obviously its not going to take a whole lot of time for a single coat; i'd like to be able to use the roller for 2 coats at least.
Thanks.
Thanks.
bob84- Rank
- Number of posts: 49
Project: 1984 corvette
Registration date: 2007-12-09
Re: What does everyone do with their rollers between coats?
I used the same roller for about 4 coats. Then a new roller on coats 5, 6, and 7 and then for the final coat I used a new fresh roller. In between coats I squeeze all of the paint out and wrapped the roller up in aluminum foil and a plastic bag. When using the aluminum foil, just wrap it up snug not tight because you don't want to distort the roller. Then take a plastic bag and put the roller inside and wrap the rest of the bag around the handle. Worked great for me
:: Matt, Administrator
Matt- 400+ Poster!
- Number of posts: 563
Project: Ford Ranger Splash
Registration date: 2007-12-08
JI wrap it in a plastic bag from the grocery store and then store it in the freezer overnight. Doesn't dry out and maintains it's . . . density!
Dave74- Rank
- Number of posts: 26
I put mine in a small plastic bag and tied it off to keep as much air out as possible. I probably could have used the same roller for the entire truck but since I bought a multi-pack of the rollers I did coats 5 and 6 with fresh ones.
frank1380- Rank
- Number of posts: 22
Project: 1997 Ford F-150
Registration date: 2007-12-12
I started like suggested here storing my used rollers in Aluminum foil in freezer - BUT - now want to share the method I started using which I like BETTER, Zip Lock sandwich bags,
you can open the bag take your roller handle and place the roller within the bag in your hand and then PULL it OFF w/o getting paint all over yourself and then when you go to use it
again just reverse the bag in hand process and throw away those two baggies.
Michael
Michael
cyberized- Rank
- Number of posts: 65
Job/hobbies: Retired
Project: 1984 El Camino Conquista
Registration date: 2008-02-03
I used saran wrap over the end of the roller. The "cling" seemed to work rather well, kept the foam fresh.
dakotapalm- Rank
- Number of posts: 1
Registration date: 2010-01-28
All good ideas. Anything to keep the air away from the paint. I have used the baggies for paint brushes also but I like the saran wrap idea also.
retired plumber- 800+ Poster!
- Number of posts: 968
Similar topics» What does everyone do with their rollers between coats?
» Spraying Brightside - How many Coats?
» Luxurious Rollers "Metal Godz"-Rockabilly Syndicate-Bandung
» MEDWAY ROLLERS SAC
» Low Rollers
» Low Rollers
Page 1 of 1
