roll on automotive acrylic enamel?
Rolled On Forums :: Rolled On Forums :: Exterior :: Rolling
Page 1 of 1 • Share •
Im wondering if I could use the rustoleum method with some automotive enamel? I have a gallon of it that I bought on evilbay a few years ago and never used it.it came with hardener but I would use it without that.and just thin it way down like with the rusto.
operator1- Rank
- Number of posts: 2
Registration date: 2008-05-07
Re: roll on automotive acrylic enamel?
I would like to know also because i have quite a bit of auto paint lift over myself and its all metallic. I would think that it would work fine untill the last color coat (especially if its metallic). I wouldn't sand that coat untill I put 2 coats of clear over it to protect the metallic from being sanded. If you don't have metallic then I don't see a problem. All that can happen is it won't work and then you can sand it off and redo it but I think you will be ok. I know when I do mine that is what I am going to use and that is how I am going to do it.
Metallic might be a problem but using the roller in several directions should ward off any streaking or tiger striping because you can see it and compensate with the roller.
retired plumber- 800+ Poster!
- Number of posts: 968
Similar topics» roll on automotive acrylic enamel?
» Using acrylic enamel with hardener?
» Painters how long will acrylic enamel last in the can?
» Napa Crossfire Acrylic Enamel respray
Page 1 of 1
