cant find paint?
cant find paint?
Post by fishy on May 28th 2008, 7:11 am
im in ireland and cant seem to find the correct paint. someone please help. can someone tell me if this would work. its made by rustoleum. and it says its based on a urethane modified alkyd. its also high gloss which is what im looking for. http://www.paintshop.ie/Details.aspx?ID=43&name=CombiColor
thanks
fishy
Registration date : 2008-05-28
Re: cant find paint?
Post by retired plumber on May 31st 2008, 1:15 pm
That sounds like it would work. As long as it is NOT water based you should be ok. Make sure you use the proper reducer (will say on the can) with it. Uretrhane is one of the older type of auto paints.
Remember tho, If you are rolling you will have orange peel even tho it will be glossy. Maybe you can live with that but to get rid of the peel you will have to sand which takes away the shine so that will require buffing to get the shine back.
Post by Matt on August 28th 2008, 12:25 am
Mike is right. Rustoleum makes products outside of the U.S. and while it's usually the same product, they put a different name to it. For example, Canada's version is Tremclad which is still owned by Rustoleum. Good luck with your project and let us know if there is anything else we can do.
