Couple of prep questions about filler / primer / paper
Page 1 of 1 • Share •
Ok, I am working this all by hand I don't have power tools.
I have located 4-5 rust bubble areas on my car, and 1 small ding on the front fender I'm talking the size of a quarter and about 1/8 inch deep. I will attempt to massage the ding out with a dolly.
1.) What grit do I sand down the ding and the rust to bare metal with?
2.) One of the rust spots is a little flaky, can I use a soft wire wheel on my drill to take that area down to metal?
3.) What grit do I level out the filler with? I'm working by hand, so would it be easier to 2 step it and hit 240 then 400 or something?
4.) After the body filler has been smoothed by sanding, should I spray some primer over it just to cover it up so the paint sticks?
5.) Once the body work is done, what grit do I sand the entire car with?
6.) Once the cars sanded and even, do I need to prime the entire car? I plan on rolling Rustoleum Gloss Black.
Slick- Rank
- Number of posts: 6
Job/hobbies: Automobiles, & Photography
Project: 1986 Camaro
Registration date: 2008-12-19
Re: Couple of prep questions about filler / primer / paper
Hi Slick
To answer your questions.....
1 and 2..... using a wire brush in your drill will be best.
3....Get the filler as smooth as possible when applying and then I usually start with something like 150 and then progress to finer. Anything over 300 is real slow on filler.
4...yes you need primer. Remember, if you can see body work through primer, you can see it through the finished paint (BLACK SHOWS EVERYTHING). Also ,primer is not to be used as a scratch filler but it will do it a bit. Spray can stuff won't but if you get a quart and mix it..............I have even painted it on with a brush but don't tell anybody LOL.
5...I use 320 or 360.
6...Yes the whole car should be primered so the underbase is one solid color, even when using black. Again ,I would use 360 grit for this.
Good luck
Good luck
retired plumber- 800+ Poster!
- Number of posts: 968
Similar topics» Old MEAD PAPER Track # 250 is owned by ODNR
» Dojave su najjcesce za u glavnom za druge lige na primer ( Grcka 2 , Turska 2 ... )
» Some weird questions..
» Polls/Questions for the RCF Universe
» A couple of new staff appointments
Page 1 of 1
