Test Piece With Roll-On Method
Post by T-Bucket Bob 23 on January 4th 2009, 10:28 pm
This is the piece I started with:
1. Primed and Cleaned with mineral spirits: Click on picture thumbnail
2. I mixed 1/4 qt. Sunburst Yellow and 1 cup mineral spirits.
3. First roll-on picture:
4. I waited about an hour and apply a second coat:
I plan on doing some more painting this week and then start to sand. What grit should I start out with after 2 coats?
Thanks, T-Bucket Bob
T-Bucket Bob 23
Job/hobbies : Shipping - Receiving Clerk
Project : 1923 Ford T - Bucket
Registration date : 2008-12-29
Re: Test Piece With Roll-On Method
Post by megaglow_z on January 5th 2009, 3:14 am
I did 400 grit to get the nubs out and smooth. You need to sand in between at least every 2 coats to assure it stays smooth. as i got close to the last coat, i did 400 grit, followed by a VERY light 800 grit with alot of water to get the 400 sand marks out. then shot the last coat.I did satin so i did not sand the final coat, but if you have any nibs or bumps, you will probably want to use 2000-2500 grit to smooth before buffing and polishing.
Also be sure to ALWAYS WET sand, never dry sand.
Post by zoelife on July 16th 2009, 6:42 pm
im only wet sanding with 800+ im scared ill mess up the paint lol
zoelife
Number of posts : 55
Job/hobbies : security gaurd getting ase certified
Project : 2000 cavalier
Registration date : 2009-07-12
