Rolling Tips / Lessons Learned
Post by jtwh20 on January 25th 2009, 2:16 pm
Just a few lessons learned from my experience rolling:
1) Mixing your paint - I use a 2 1/2 quart plastic bucket - Pour in 1 qt of Rustoleum, then pour your mineral spirits into the empty can, close it up and swirl the can around but do not shake - Now pour the mineral spirits into your bucket - Stir, Stir Stir - it will take minutes to get it mixed well...
2) You can never have enough tape - If you think you need only 1 roll get 2...
3) Only pour enough paint into the tray for ONE panel - this keeps the paint that is in the tray from starting to harden a little - when you use up that pour out a little more...
4) If you are doing a big vehicle (my suburban is huge) you may need to change rollers - I used 1 roller for each side, as I found the roller would get built up with paint...
5) Take your time - I think charger69 said patience - Yep this is in no way a fast process...
6) The more time between coats the better - I found that between my 2nd and 3rd coats, the paint REALLY started to harden and flatten itself out - might be because of the cold, but for me, I put 2 coats on 1 weekend, (drive to work all week, find a sunny spot to park) then 2 more the following weekend - you could still smell the paint drying most of that time...
Anyway, that's my 2 cents - Good Luck to all who try this method!
jtwh20
Number of posts : 8
Registration date : 2009-01-07
Re: Rolling Tips / Lessons Learned
Post by retired plumber on January 25th 2009, 4:14 pm
Good tips. Thank you. Its always nice to have imput and comments on the process from the people who are actually doing it.
Post by megaglow_z on January 27th 2009, 12:39 am
Thanks for those man, i like the 1st one. also as a note, if you have to get a lot of paint cause you have a big *** vehicle, mix all the cans in a bucket, then pour them back into there cans and seal. this makes sure you don't have a color difference between cans.
