Temperature Changes
Temperature Changes
Post by Dave74 on December 13th 2007, 11:58 am
I rolled the first three coats with the outside temperatures in the 30's and snow on the ground and an unheated garage with garage door open. I didn't have any problem with orange peel or runs when rolling it on and it went on like glass. On coat four, a warm front came in and brought temps up into fifties and sixties. I just went out to color sand and put another coat on, and I got an entire trunk lid full of orange peel.
The only thing that changed was the temperature. So, just an observation that could help someone else.
Dave74
Number of posts : 26
Re: Temperature Changes
Post by frank1380 on December 13th 2007, 12:56 pm
I think that the humidity also plays a role. If it's more humid one day than another I think the solvents in the mineral spirits will evaporate slower so you'll get better planarization. The downside being it may take forever for your paint to dry.
frank1380
Number of posts : 22
Project : 1997 Ford F-150
Registration date : 2007-12-12
Post by MR_Se7en on December 14th 2007, 9:25 pm
^^^ living in texas i can account for the humidity factor. it really suxs when your trying to mix paint
MR_Se7en
Number of posts : 9
Registration date : 2007-12-10
Post by Matt on December 20th 2007, 1:28 am
hmmm I painted mine in a garage at around 75 degrees. I noticed when I first started that I got a lot of orange peel if I mixed in a little too much paint in the ratio. Were you using the same batch of paint?
Post by dumkopf on December 20th 2007, 11:20 pm
So what's the word on the paint and temp? I didn't think warmer temps would make a difference.
dumkopf
Post by Matt on December 20th 2007, 11:33 pm
Well paint is going to dry quicker with a warmer climate. The way I see it, warmer climate = quicker dry time = less self leveling. If your painting at a slightly cooler climate then the paint doesnt dry as quick and it extends the time the paint has to level out. If you use thin coats at a cool climate then you should have very little orange peel. In theory that is.
