How is everyone getting ride of the wet sanding scratches?
Post by RolledCivic on December 14th 2007, 1:33 am
What is everyone using to get rid of the wet sanding scratches? What tools and compounds?
RolledCivic
Number of posts : 6
Project : 1995 Honda Civic Coupe
Re: How is everyone getting ride of the wet sanding scratches?
Post by stuff215 on December 14th 2007, 1:34 am
I used 3m rubbing compound when I wetsanded with 2000 grit sand paper. Anything lower is going to be harder to remove.
stuff215
Post by Matt on December 14th 2007, 1:50 am
huh not sure if I follow. I didn't have any problems with scratches. Make sure when your sanding you use PLENTY of clean water. Don't use water thats been sitting in a bucket for days or anything. You may have caught a small piece of dirt between the sandpaper and the surface. Usually if this happens the sandpaper will feel like it's rolling instead of sliding and will have a zipper sliding sound to it. What coat are you on? If they are fine scratches and your not too far into the project, the next few coats should fill them in. If it's your last coat I would try wetsanding again with a new sheet of high grit paper (1500-2000) and clean water and see if that takes them out. A lot of those imperfections will come out when you buff as well. Keep us posted on how things go hope
Post by RolledCivic on December 14th 2007, 1:09 pm
Matt,
Technically when you are wetsanding you are putting millions of fin scratches in to the paint creating a dull effect. I was just wondering what products everyone was using to buff the dullness and bring the shine back.
I'm on my 8th coat and have wet sanded after every 2 coats. I'm going to do a final wetsand to get rid of any of the last imperfections. Can you buff it out by hand? Or should I spring for the direct drive rotary buffer/sander?
Thanks,
Jonathan
RolledCivic
Number of posts : 6
Post by MR_Se7en on December 14th 2007, 9:28 pm
what grit are you using?
MR_Se7en
Number of posts : 9
Registration date : 2007-12-10
Post by (null).exe on December 17th 2007, 12:10 pm
I use a normal dish sponge and wrap the sand paper around it.
Also, i have running water directly from the hose that i sand with.
Make sure you're not pressing too hard when you sand, you want to buff with the paper, not grind.
I'm going to use meguiar's cleaning wax and an orbital buffer for my final step.
(null).exe
Number of posts : 25
Job/hobbies : Air Traffic Controller, Track Racer, Competitive Fencer.
Project : 1993 Honda Prelude VTEC
View user profile http://nullexe.deviantart.com
Post by Matt on December 20th 2007, 1:25 am
null has the idea. Remember your wanting to smooth out the finish so the softer you are with your final wetsanding stages the better. Try using the cross hatch sanding method with plenty of water and just let the sandpaper do the work. People also say they have good results using a circular motion while sanding.
Post by after on January 24th 2008, 10:42 am
when finished wetsanding between coats, do you wash the residue paint dust and then wait to dry to apply paint?
after
Number of posts : 37
Job/hobbies : Customer service/fishing
Project : 1994 Honda civic hatchback. Going back to all original interior and restoring car
Registration date : 2008-01-23
Post by btldigger on January 24th 2008, 11:02 am
That how I have done it. just wash the whole thing with clean water and a rag.
btldigger
Post by after on January 24th 2008, 11:07 am
btldigger thanks! thumbs up
after
Post by Roadking41a on January 24th 2008, 3:22 pm
Does it hurt to use a sanding block instead of a sponge?
Post by karlbasher on January 24th 2008, 3:38 pm
i dont have scratches and i did 800 grit and then buffed it out with 3 compunds 1 3m rubbing compuind, 1 meguirs fine cut cleaner, 1 meguirs polish,
karlbasher
Number of posts : 83
Registration date : 2007-12-24
Post by Techmaven on September 29th 2008, 3:01 pm
I've also wet sanded using a jitterbug sander with wet/dry paper. It really speeds up the process. As always, you should keep a squeegee handy to check progress.
Techmaven
Post by tpirsig on July 9th 2009, 3:40 am
Techmaven wrote:I've also wet sanded using a jitterbug sander with wet/dry paper. It really speeds up the process. As always, you should keep a squeegee handy to check progress.
What the heck is a jitterbug sander? Like a palm sander?
tpirsig
Number of posts : 21
Project : Pile of Volvos, '87-'91 / turbo / 740-760-940
Registration date : 2009-05-16
Post by Techmaven on July 9th 2009, 12:51 pm
Yes, a palm sander.
Techmaven
Post by RoboGeek on July 9th 2009, 1:47 pm
use air powered - not electric.. hehe
Post by zoelife on July 16th 2009, 7:18 pm
i always sand in the same up and down pattern with dawn in my water and change the water every time i am done with the wetsanding then i wash and try the paint im about to start my first coat of the two tone im doing after the second coat ill sand with 800 grit wet then 2 more coats 1000 grit and keep moving it up 200 depending if i get bubbles or orange peel. being 90 in the area im painting im going to get a few bubbles =[
zoelife
Number of posts : 55
Job/hobbies : security gaurd getting ase certified
Project : 2000 cavalier
Registration date : 2009-07-12
