Supermarine Paint
Supermarine Paint
Post by mapexgurl on July 27th 2009, 11:09 am
I'm soon going to try a roller job on a 1972 Charger. The car is purple now and I would like to do purple again.
http://www.supermarinepaint.com/topside-mono-coat-SM-2020.asp
That is the only marine paint I could find that offered a purple (as well as many other colors.) Would this paint work?
These are all the Topsides they offer. I would like a single stage. Which would would be the best one?
http://www.supermarinepaint.com/topside-paints.asp
Also, I've been sanding the car down. Do I need to sand past the clear coat?
I hope the final result will be purple with black strips and the og vinyl top back on.
Project : '72 Charger
Re: Supermarine Paint
Post by RoboGeek on July 27th 2009, 6:04 pm
only if the clear is failing..
never used that paint so I'll refrain from trying to answer that - but I will say it will take quite a bit of paint for that critter - thats a big car!! I painted a couple of those before (spray) and both times ran out of paint. No fun on one since it was candy apple red and that paint is EXPENSIVE!
