Interlux Brightside questions
Post by jwv3 on January 6th 2010, 5:42 pm
New guy here and have a question on the Interlux Brightside paint.
Do you use mineral spirits to thin it like you would with the rustoleum?
After reading the product description it mentions chemical resistance. Anyone tested this by spilling gasoline on it? I'm going to paint a motorcycle tank and wonder how it will hold up to gas dribbles.
Thanks for the site and great info on roller painting!
jwv3
Registration date : 2010-01-06
Re: Interlux Brightside questions
Post by 63Falconconvert on January 7th 2010, 9:12 am
Thats a good question that has been kicked around a lot. On older cars like my Falcon the gas always splashes back when pumping and runs down the panel. I'm not sure what you can reduce Brightside with, there should be some info on there web site. I know when I'm ready to paint the Falcon I'm going to use enamal reducer and hardener instead of mineral spirits. Check out these sites, there may be some good info you you.
http://rollyourcar.com
http://www.rickwrench.com
Post by Hype on January 9th 2010, 10:55 pm
Experienced Brightsider here -
You can thin with mineral spirits. The can says no not mix more than 10%, but some have had luck with as much as a 50/50 mix. Yours will likely be somewhere in the middle depending on humidity, how many layers of paint you're applying etc etc...
Mix a small amount at a time and play with the mixture. You should end up with like a 2% milk consistency lol. Let us know!
Hype
Registration date : 2009-08-09
Post by btldigger on March 15th 2010, 12:25 am
I havent tried mineral spirits with it but I did use xylene. That is actually what the 216 thinner they recommend is.
btldigger
Post by Hype on March 15th 2010, 12:48 am
Hmmm xylene, didn't know that. How does it compare with mineral spirits?
Hype
Post by toy4x4fever on May 3rd 2010, 2:11 am
I used the regular mineral spirits seemed to work better for me than the odorless stuff!
toy4x4fever
Number of posts : 51
Job/hobbies : toyota pickups
Project : 94 toy pickup
Registration date : 2010-03-17
