Hello from Spain.
Hello from Spain.
Post by vasp on March 28th 2010, 6:16 pm
Hello. I´m from Spain.
First of all, sorry for my bad English.
I have seen some of your work and they look spectacular!!!
Now I'm thinking of roll my Mercedes W123. I have read a lot but did not found the answer to a few questions:
¿What is the reason to use mineral thinner? ¿What could happen if I use (for example) acrylic thinner?
¿Could I use 2k Acrylic Car Paint? If yes, ¿Should I thinn it mit mineral thinner?
In Europe I can´t find Rostoleum. ¿Do you think than any rust paint schould work?
It seems that nothing in Europe has do this work. The only information that i can find is in America...
Thank you in advance for your answers.
vasp
Registration date : 2010-03-28
Re: Hello from Spain.
Post by stang_krazy on March 28th 2010, 8:15 pm
Welcome to rolled on vasp
Just learning about this type of painting so sorry I can't help yet, I will try to search around for some of your questions though if no one answer them in alittle bit.
Post by retired plumber on March 28th 2010, 11:29 pm
Welcome vasp
I will try to answer some questions for you. The mineral spirits are slow drying so that gives you time to roll the paint and get rid of roller marks by going over it several times in different directions. I don't know if 2K paint will work or not but I know rusto makes paint and sells it all over but it has different names elsewhere. In Canada it is called trimclad or something like that. Go to the rusto web site and take a look around. If they sell it in Europe, I'm sure it will say so somewhere and give it a name.
You are not looking for "rust paint", you are looking for enamel that can be reduced with mineral spirits (oil based). If you ask the sales people what it can be reduced with they will probably try to sell you some fancy brand name reducer so look at the can or ask if it can be cleaned up with mineral spirits. That is what you want. Also stay away from latex enamel because that is water based and is usually an indoor wall type paint Laughing
In the next couple of weeks I am going to try clear acylic enamel and urethane thinner because I can't find any regular clear enamel. Its all susposed to be cut with urethane thinner (they say) but I will try ms first. I want to try metalflake and it has to go on in clear. Rusto in the USA dosen't make clear in quarts anymore, just in spray cans. Anyway, This may be what you call 2K paint (different countries, different termonolgy huh ) and I will be posting my findings.
Hope I answered a couple of your questions and your English is fine. Actually it is better than my spelling LOL.
Post by 63Falconconvert on March 29th 2010, 8:05 am
Welcome......Glad you found us all the way from Spain.
Post by vasp on March 29th 2010, 11:20 am
Thank you very much for your answers Very Happy
retired plumber wrote: This may be what you call 2K paint
2k paint is 2 component pait: paint + hardener. Yes, I think it could be what you mean. I have some from my last spray job and in a few days I will try to thinn it with mineral thinner.
vasp
Post by RoboGeek on March 29th 2010, 2:14 pm
hola! Welcome to the forums!
btw.. your english is better than some of the americans on here! lol
Post by retired plumber on March 29th 2010, 5:47 pm
I know for a fact that mineral spirits and polyurethane DON"T mix because I tried it. I am hopeing that regular urethane will mix with it. They both can have hardner added to them to make 2K paint but their chemical makeup is different, as is the hardner. The poly stuff needs the hardner to even set up. I sprayed the roof of my truck and left the hardner out of it on purpose to see what would happen. You guessed it, it was tacky for a month and 6-7 months to dry hard and when it did it was full of cracks. It looked like dried mud. Laughing. I'm just hope urethane enamel will work but I will find out pretty soon.
