1993 Jeep Wrangler Gets The Roller
Page 2 of 2 Previous  1, 2
Re: 1993 Jeep Wrangler Gets The Roller
Post by buckz on April 3rd 2010, 11:52 am
Photos after 6th coat, i finally rolled it outside to bake in the sun for a while before I wet sand tomorrow.....the photos really do not to it much justice, it looks great!
I'm not this fat, 6' and 170, but this is on a curve....lol
buckz
Number of posts : 35
Registration date : 2010-03-29
Post by stang_krazy on April 3rd 2010, 12:22 pm
It's OK buckz, we don't care what you look like. We still like you! lol!
Post by RoboGeek on April 3rd 2010, 1:21 pm
look out!! You'll make the neighbors jealous
Post by buckz on April 3rd 2010, 1:49 pm
I can not wait to get the stainless trim on it and put it back together. Going to be done monday!
buckz
Post by RoboGeek on April 3rd 2010, 6:14 pm
I love when a plan comes together!
Post by buckz on April 5th 2010, 10:50 am
This is a double post, sorry but I wanted to get feedback...
I just finished up my 7th coat, everything looked AWSOME until now..... I sanded with 1200, but for some reason the wet sand did not feel good and kept catching everywhere i sanded. This was the 4th time I wet sanded the jeep and I had great results. I used clean water and a little dish soap, cleaned the serfaces before i sanded, changed paper 6 times etc... There are very noticable scratches in my Jeep...all over it. There are not deeep looking and you cant feel them. My question is this, should i wet sand it again tomorrow or just keep painting over them until they are gone and call my paint job done. I was planning on putting on my last coat tomorrow morning and putting the jeep back together, I am really bummed right now.
buckz
Post by buckz on April 5th 2010, 10:53 am
The scratches would not really show in a phot or I would have posted one, you can only really see them when the light is right
buckz
Post by RoboGeek on April 5th 2010, 2:50 pm
sounds like the paint wasn't totally dry yet. I had that happen - that was one of my 'ruined' coats. The sanding just didn't feel right, the paper caught all the time, and the paper clogged constantly. That created scratches all over the place..
If you have enough paint on it, it should wet sand out. That close to a final coat you want the surface as close to perfect as you can get it, but f they are that light you might get away with it.
And remember - if you don't like it - its very easy to fix it!
Post by buckz on April 5th 2010, 3:08 pm
Thanks for the reply. I am going to let it dry today and wet sand it out tomorrow crossing my fingers that there is enough paint to get all the scratches out. I will keep you all updated
buckz
Post by retired plumber on April 5th 2010, 4:12 pm
Bummer but like robo says, its an easy fix. One more coat should do it if thay don't sand out first.
Good luck
Post by 63Falconconvert on April 5th 2010, 4:24 pm
are you using a hardener?
Post by buckz on April 5th 2010, 4:59 pm
I am not using a hardener, should I be? would it help with the wet sanding?
buckz
Post by RoboGeek on April 5th 2010, 6:08 pm
if its not real hot there yet you can allow longer cure times, use heat lamps, park in the sun or use hardener.
You could do a coat or two, and let that cure for a few weeks, then sand it out and it would probably be fine.
But I'm really thinking hardener is the way to go with these paint jobs. But you have to use it from the first coat. If you used hardener now, there's a real good chance you would trap volatiles from the previous coats under your last ones.
That would not end well....
Post by buckz on April 6th 2010, 1:43 pm
I just finished wet sanding and it looks like it came out good. I will keep my fingers crossed and post an update after i lay down the next coat.
buckz
Post by 63Falconconvert on April 6th 2010, 4:45 pm
good luck!
Post by buckz on April 8th 2010, 12:00 am
Sorry I have not posted for a little while, but I just finished my 9th coat and it is going back together tomorrow. It ended up putting 3 coats back on it after I sanded the scratches out to get full coveage. I have some "uneven spots in the paint, but I am hoping they will buff out. Did any of you have some uneven stops in the paint when you finished? They are little dull compaired to other areas...hard to explain.
One more question, do you think it will be ok to start bolting things back on after 12 hours of 55 degree damp weather...it is sitting in the garage.
I cannot wait to put it back together and roll it outside to get a good look at it, looking at it under the floresent lights all the time will drive you crazy....Here are some photos I snapped tonight, many more will follow tomorrow!
Thanks to everyone for the help Very Happy
buckz
Post by 63Falconconvert on April 8th 2010, 10:17 am
looks really good...I would let it cure for a few days before putting it back togther, but thats just me.
Post by stang_krazy on April 8th 2010, 5:23 pm
Yeah I agree with Falcon
Since the humidity is high the paint is going to need more time to dry, and you've got it looking good so I wouldn't rush and apply bolt scratches and nicks.
And it being black the littlest thing will show up as soon as you roll it out into the direct sunlight.
When I'm detailing and it's raining or getting ready to rain I keep an eye on my humidity gauge and when it gets to high (75% is boarderline for me) I will turn on my window mount AC to pull out the huimidity in my garage so I can keep keeping on and wont have any problems with curing and removing my products.
Post by buckz on April 9th 2010, 5:06 pm
The Jeep is done, going to buff it in 30 days, but it looks great. I only have a couple outside photos because the weather is crappy. My good friend owns a auto body shop and I stopped by there today because he is going to help me weld a frame peice and he could not believe I painted it with a roller....he called all of his employees out to look at it. He only belieived me after I showed him the photos of me painting it. I will post more photos tomorrow...THANKS to everyone for the help. I will also post more details about painting the Jeep and the bodywork, I'm moving in 12 days and need to get other stuff done.
buckz
Post by T.Hadley on April 9th 2010, 7:01 pm
It look awesome, I hope ours comes out that good.
Post by 63Falconconvert on April 10th 2010, 4:22 am
congrats....looks great thumbs up
Post by retired plumber on April 10th 2010, 2:42 pm
thumbs up
Post by buckz on April 10th 2010, 4:35 pm
How long should I wait to wash this thing? It is very dusty from sitting in the driveway baking in the sun.
buckz
Post by RoboGeek on April 10th 2010, 4:51 pm
well, since it basically gets washed when you wet sand, it should be ok as soon as its dried.
I might refrain from any detergent or wash for a bit, but mine sat in the rain and hail for 2 weeks right after it was painted with no effect
