1975 Opel Ascona - Spray with ACE Rust Stop
Page 1 of 1 • Share •
Been wanting to try this for some time now. Read about it about 4 years ago and I have played with some spraying earlier this year so going to give it a try. Right now I am working on a hood. My old hood is in sad shape with some rust through. A friend gave me another hood so this is my project for now. If it turns out OK I will be painting the whole car.
The hood given to me had set out in the weather for some time, but it is in better shape than my current hood. There is some small dings and some rust pitting on the rear ledge from sitting in the dirt. I used some POR-15 on these areas and now I have painted the bottom side with gloss black and today I sprayed primer on. I am using ACE Rust Stop primer and it laid on great with good coverage with a 3-1 mix using a cheap air brush from harbor freight.
ghcoe- Rank
- Number of posts: 23
Registration date: 2010-06-05
Re: 1975 Opel Ascona - Spray with ACE Rust Stop
A shot of the hood with first coat of primer. Still need to sand and fix dents and pits.
ghcoe- Rank
Woohoo, another Opel guy here!
Jim
Jim
JimVonBaden- Rank
- Number of posts: 89
Job/hobbies: DHS
Project: 1973 Opel GT
Registration date: 2010-05-24
Yup, I am on the Opel forum too. Same user name.
ghcoe- Rank
Yeah, I recognize you!
Who knows? Maybe we will start a new trend!
Jim
Jim
JimVonBaden- Rank
Job/hobbies: DHS
Well I guess that would depend on our end results. I am feeling pretty good about it now, but only time will tell.
ghcoe- Rank
Once I primed and sanded all the small stuff I ground the larger dents out and applied bondo this is the first time I had good luck using bondo.
Bondo sanded.
Reprimed sanded and spot putty. One more coat of primer after this
$14.99 Harbor Freight detail sprayer and $2.99 water trap. I have a trap on the compressor thought a little extra protection would be good though. Gun worked awesome.
Hood after 4 coats of paint. I used ACE Rust Stop satin black for the flat hood look. I sprayed in direct sun to keep the bugs off after having a bug issue in the morning. I did two coats back to back and then waited 1 hour and then two more coats.
Old hood.
New hood installed.
Bondo sanded.
Old hood.
New hood installed.
Last edited by ghcoe on June 16th 2010, 8:27 pm; edited 1 time in total (Reason for editing : Added what paint was used.)
ghcoe- Rank
Looks great! Are you planning some sanding?
Jim
Jim
JimVonBaden- Rank
Job/hobbies: DHS
Whoops, I forgot to mention that it was suppose to be dull. I used ACE Rust Stop satin black for the flat hood look. Trying for the period European Rally car look when done. Fix it in comments above. George.
ghcoe- Rank
Those cars are so cool! Nice work!
~Johnny V
~Johnny V
JohnnyV- Rank
- Number of posts: 64
Project: 98 Dodge Dakota Sport
Registration date: 2010-03-26
JohnnyV wrote:Those cars are so cool! Nice work!
~Johnny V
Thanks!
ghcoe- Rank
Similar topics» Opel Zafira Tourer
» DPI Autocolor spray paint & Autospa color..
» Revolution: Direct Hit XXI: The Last Stop before War Games: 3/22/10
» leaving if bullshit dont stop
» 1975 Opel Ascona - Spray with ACE Rust Stop
Page 1 of 1
