Help me get a list together
Post by litebulblsc on August 14th 2010, 9:02 pm
I am wanting to run to Lowe's tomorrow to pick up supplies to get my Blazer in primer.
I am going to roll it with Rustoleum clean metal primer.
http://www.lowes.com/pd_98838-90-V7580502_0_?productId=3069751&Ntt=rustleum+clean+metal+primer&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=rustleum%20clean%20metal%20primer$y=0$x=0
I believe this is the correct roller
http://www.lowes.com/pd_165861-11591-97604_0_?productId=3192753&Ntt=foam+roller&Ntk=i_products&pl=1&currentURL=/pl__0__s?Ntt=foam%20roller
Although the roller refills are unavailable at my store
http://www.lowes.com/pd_119118-11591-94068_0_?productId=3140735&Ntt=foam%20roller&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=foam%20roller$y=0$x=0
Mineral spirits to thin it down with
http://www.lowes.com/pd_58938-78-GKGO75000_0_?productId=3036211&Ntt=mineral+spirits&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=mineral%20spirits$y=0$x=0
I was wondering if any one has a link to good brushes or other supplies that I may need. I think I need a paint tray too.
Thanks for any help,
Josh
litebulblsc
Number of posts : 24
Registration date : 2010-07-10
Re: Help me get a list together
Post by litebulblsc on August 15th 2010, 10:10 am
I think I am going to get this instead of the other roller as it is cheaper and comes with a tray.
http://www.lowes.com/pd_144257-11591-97614_0_?productId=3013608&Ntt=whizz+door+and+cabinet&Ntk=i_products
Also found a 6 pack of rollers at my store
http://www.lowes.com/pd_235017-11591-94062_0_?productId=3026938&Ntt=whizz+door+and+cabinet&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=whizz%20door%20and%20cabinet$y=0$x=0
litebulblsc
Post by JimVonBaden on August 15th 2010, 10:21 am
Looks pretty good.
I would suggest some quality paper towels, automotive grade is best. Also some rubbing alcohol for wiping down your surface between paint coats and after sanding.
You also need polishing materials. See my Opel Barn Find project thread for details. Barn find, click here
Good luck,
Jim Cool
JimVonBaden
Number of posts : 89
Job/hobbies : DHS
Project : 1973 Opel GT
Post by sherbasm on August 15th 2010, 12:09 pm
are you going to be painting over the primer with more rusto? i'm wanting to use interlux brightside paint on my truck but i'm very new to this idea and am curious to know if primer really matters with one step paints.
sherbasm
Number of posts : 7
Registration date : 2010-08-10
Post by litebulblsc on August 15th 2010, 12:16 pm
Yes I am going to use Rustoleum over the primer. The main reason I got the primer is that I am going to take the body down to bare metal to see what I am dealing with. Then I am going to primer over it. Then once the body is all good, I bought some safety red to go over the primer with.
Oh yeah, just got back from the store. Bought the starter kit, 10 roller pack which was in stock, primer, red paint and mineral spirits. I probably need to pick up some brushes still.
Pretty hot and nasty out, plus it is suppose to rain today, so not sure If I will make any progress, but if I do, I will take pictures and start a thread in the project section. I want to talk to my dad about it before I start too.
litebulblsc
Post by JimVonBaden on August 15th 2010, 8:06 pm
sherbasm wrote:are you going to be painting over the primer with more rusto? i'm wanting to use interlux brightside paint on my truck but i'm very new to this idea and am curious to know if primer really matters with one step paints.
That is how I did it. The even color of the surface reduces the number of coats.
Jim Cool
JimVonBaden
Job/hobbies : DHS
Post by litebulblsc on August 15th 2010, 8:14 pm
Plus on the can, it says the primer helps to protect the metal more from rust, which is my main goal.
Got $51.83 into it so far.
litebulblsc
Post by Squire Cobra Jet on August 15th 2010, 9:41 pm
If the color already on the car is all one color and has had a good sand over with some 400 grit you don't need to use primer. If you have spots where you have done some body work and either have filler or raw metal showing it will take less coats if you primer those spots first.
Post by Squire Cobra Jet on August 15th 2010, 9:48 pm
litebulblsc wrote:I think I am going to get this instead of the other roller as it is cheaper and comes with a tray.
Those should work fine. You can either use once and toss or if you keep the used roller in a container with a mix of mineral spirits and water you can reuse the same roller. Just make sure no paint has dried on the roller. If there is even the slightest bit of dried paint on the roller, toss it and use a new one.
Post by Squire Cobra Jet on August 15th 2010, 9:52 pm
litebulblsc wrote:Plus on the can, it says the primer helps to protect the metal more from rust, which is my main goal.
If there is already rust, you will need to remove it or at least neutralize it before applying paint. There are special primers that are designed to neutralize rust. Regular primer and paint will not stop rust.
Post by litebulblsc on August 17th 2010, 5:15 pm
Yes I plan to get rid of all the rust first, that is why I bough clean metal primer.
litebulblsc
Post by litebulblsc on August 21st 2010, 10:13 pm
Haven't given up guys. Going to get some new doors and fenders tomorrow. Also waiting on my brother to finish his truck so I have some room in the garage. The supplies are sitting there just waiting for me to use them...
litebulblsc
Post by litebulblsc on August 22nd 2010, 8:41 pm
I bought a new top for the Blazer. It is fiberglass and I want to get paint on it asap. I am having a hard time finding a store the offers Marine Rustoleum paint. Any ideas how I can get my hands on some?
litebulblsc
Post by retired plumber on August 22nd 2010, 10:00 pm
Why marine paint? Its fiberglass so regular rustoleum should be fine. You would want to scuff sand it first of course. Fiberglass dosen't require special paint. What works on metal will work on fiberglass however I have heard there is a fancy primer for "plastic" that comes in spray cans you might want to look into.
Post by Squire Cobra Jet on August 23rd 2010, 12:55 am
The "Marine Rust-Oleum" is the Topside brand which has U.V. protection which the regular Rust-Oleum does not. It also has a bit more gloss to it. I have been buying The Topside from Amazon.com and I have been paying close to the same price that I had been buying the regular Rust-Oleum in stores. I been getting free shipping from Amazon on the Topside.
http://www.amazon.com/Rust-Oleum-207002-Marine-Topside-1-Quart/dp/B0019K5XH0/ref=pd_sim_hi_4
Post by litebulblsc on August 23rd 2010, 5:07 am
This is what I wanted to start with as it has raw fiberglass showing
http://www.rustoleum.com/CBGProduct.asp?pid=8
litebulblsc
Post by Squire Cobra Jet on August 23rd 2010, 5:13 pm
Amazon has it.
http://www.amazon.com/Rust-Oleum-207014-Marine-Fiberglass-1-Quart/dp/B000C025GA/ref=pd_bxgy_hi_text_c
Post by retired plumber on August 23rd 2010, 9:23 pm
Thanks Squire, I didn't know what the UV stuff from rusto was called.
Post by Squire Cobra Jet on August 24th 2010, 12:49 am
No problem. The more I do this kind of project, the more I learn along the way.
