Does anyone know anything about LVLP Spray Guns?
Post by Dkos on September 7th 2010, 9:14 am
Summit Racing has a LVLP spray gun for $65.00. Says it only needs 3-3.9 cfm. I was thinking this might work well with my little air compressor (rated 6.5 cfm @ 40 PSI) and Rustoleum. What do you think?
link: http://www.summitracing.com/search/Brand/Summit-Racing/Product-Line/Summit-Racing-LVLP-Spray-Guns/?autoview=SKU
Dkos
Number of posts: 8
Job/hobbies: Commercial Photographer
Project: 1972 Porsche 914
Registration date: 2008-04-03
Re: Does anyone know anything about LVLP Spray Guns?
Post by Techmaven on September 7th 2010, 12:16 pm
The description on the website is a little vague but I'd imagine it would work ok..Given that it's LOW volume low pressure, you might just have to spray at a slower pace than a standard gun?
Techmaven
Number of posts: 57
Job/hobbies: Facilities for a large company
Project: 67 Olds 4-4-2, 67 Olds Delta 88 convertible and a 93 Mercury Tracer 4 door.
Registration date: 2008-09-27
Post by Dkos on September 7th 2010, 12:18 pm
there are three diffrent tips; 13.mm, 1.4mm and 1.7mm. Which should I use?
Dkos
Number of posts: 8
Post by retired plumber on September 9th 2010, 5:37 pm
1.3 tip is for the top coats. The 1.7 tip has a larger hole which is usually used for primer and heavy bodied paints. However I have used both sizes and they will both work with either type of paint but are best with the above instructions.
I've havent heard about a LVLP gun. If you get it you will have to let us know how it works. I have a hvlp gun and my compressor is just a bit bigger than yours and sometimes I have to stop and let the compressor catch up. I can easily tell because the paint dosen't atomized as well as it does with the proper pressure.
800+ Poster!
800+ Poster!
Number of posts: 968
Post by Dkos on September 12th 2010, 10:18 am
I only want to buy one...would it make sense to buy the 1.4mm?
Dkos
Number of posts: 8
Post by retired plumber on September 13th 2010, 8:29 pm
That would be my choice.
800+ Poster!
800+ Poster!
