Excellent tutorial on various welding techniques
Post by mapexgurl on September 16th 2010, 2:00 pm
This website helped me tons on learning how to mig weld.
http://www.mig-welding.co.uk/thin-metal.htm
Project : '72 Charger
Re: Excellent tutorial on various welding techniques
Post by 63Falconconvert on November 9th 2010, 9:52 pm
excellent info...thanks for sharing
Post by Scooby on May 16th 2011, 12:53 pm
O.K so it's better to run quick small beads than one continuous bead? trying to figure this out before I weld on my rocker patch panels on my blazer. I suck at welding!
Scooby
Number of posts : 36
Job/hobbies : Computer consultant
Project : 1995 Blazer, 1998 Camaro
Registration date : 2010-04-08
Post by 63Falconconvert on May 16th 2011, 1:02 pm
yes, spot bead it. spread your beads out so all of your heat isn't in one spot. This will keep the panel from warping. Are you using .023 solid wire with gas? Flux core wire is too hot and you will burn holes really quick.
Post by Scooby on May 16th 2011, 1:14 pm
Flux core 3200 Lincoln I know! but it is all I have to work with. It has to be better than pop-rivets.
Scooby
Post by 63Falconconvert on May 16th 2011, 1:43 pm
if you have to use flu core then I would over lap your panels and not try to butt weld them together. Use .030 wire and turn your heat to the lowest setting. It can be done, but it's not easy.
Post by Scooby on May 16th 2011, 1:49 pm
Cool that's exactly what I am doing. I had the local sheet metal shop cut and bend them to go over the top of the old part. I was just going to grind the rot out and paint it then weld the new sheet metal over it. Thanks for the info! I will be making another thread on the truck as soon as the weather breaks a little bit more.
Scooby
Post by 63Falconconvert on May 16th 2011, 1:53 pm
OK free to PM me if you have any questions. I sell welding equiptment for a living, if I don't have an answer someone else here at work will. Good luck on your project.
