Rustoleum experts please explain
Post by Keegan on October 4th 2010, 9:33 pm
Could someone please explain the differences and uses for these three seemingly similar products listed on the Rustoleum site:
Rustoleum Filler Primer
Rustoleum Sandable Primer
Rustoleum Primer Surfacer
I know there's a reason for each one, but I'm not smart enough to figure it out.
Keegan
Project : 1955 Packard Clipper
Registration date : 2010-10-03
View user profile http://rhinoliningsmidwest.com
Re: Rustoleum experts please explain
Post by Lawrnk on December 16th 2010, 9:44 am
Well, i can explain the filler primer, as i use it a good deal. Filler primer sprays on much thicker than standard primer and has the qualities of a light filler like spot putty or bondo, but it is designed for very shallow nicks, scratchs, tiny dings, etc, i'd guess under 1/16 or less in depth. Its a great product, but the label is innaccurate. It states 20 minutes to dry, but even after an hour or three, its still not to the hardness i like. Overnight gives it a rock hardness perfect foe sanding down to a really smooth surface like bondo. You can use multiple coats no problem for the shallow imperfections, waiting 20 minutes at least in between. Typed on iphone, pardon my errors.
Lawrnk
Number of posts : 20
Registration date : 2010-12-15
Post by 63Falconconvert on December 16th 2010, 1:44 pm
this might shed a little light
http://www.rustoleum.com/CBGCategory.asp?cid=9
