68 Mustang Coupe
Page 15 of 15 Previous  1 ... 9 ... 13, 14, 15
Re: 68 Mustang Coupe
Post by mike460 on December 2nd 2013, 2:01 pm
Rob, I have a quick question about the primer - did you use mineral spirits to reduce it, or just roll it right out of the can? Also, how much did you end up using?
Thanks!
mike460
Number of posts : 9
Registration date : 2013-11-04
Post by 63Falconconvert on December 2nd 2013, 2:08 pm
reduce it with some lacquer thinner. Your weather will come in to play on how much to add. Heat and humidity will make paint/primmer do funny things.
Number of posts : 1261
Post by mike460 on December 2nd 2013, 2:48 pm
Thanks Bob - I've been reading up a lot in your thread, too. I am going to try to tackle my 88 F150 with Topside white, and I got a fender and a rock guard panel to begin practicing on. I'm getting pretty excited, I just haven't painted anything really since I used to build plastic car models back when I was a teenager in the mid to late 90's.....
Any insight on where to start as far as ratio goes for primer and lacquer thinner?
Thanks!
mike460
Number of posts : 9
Post by 63Falconconvert on December 2nd 2013, 3:15 pm
I would start with 75% primmer/25% thinner. Thats a good stating point. If you see the primmer dragging, clumping up then thin is some more and you should be good to go. The thing with primmer is its easy to sand and fix if you mess it up.
The key to this is using good rollers and taking your time.
Post by rmdhokie on December 3rd 2013, 6:59 am
mike460 wrote:  I am going to try to tackle my 88 F150 with Topside white....
Great! Good luck with your project. Post lots of pics!Very Happy
Post by mike460 on December 3rd 2013, 9:09 am
rmdhokie wrote:Great! Good luck with your project. Post lots of pics!Very Happy
I plan on it, the wifey just got a new Nikon D5100 while doing Black Friday (on Thursday) shopping......
mike460
Number of posts : 9
Post by mike460 on December 4th 2013, 8:56 pm
Sorry to keep asking questions - this is what they have at the local AutoZone for primer
Is this OK to use?  And should I use Rustoleum laquer thinner or the Rustoleum specialty reducer with it?
THANKS!
mike460
Number of posts : 9
Post by rmdhokie on December 5th 2013, 6:38 am
Yep. That's good to use.
