Using Japan drier to reduce tack time
Post by loneagle on December 24th 2010, 7:09 pm
Has anybody tried using the Rustoleum with some Japan Drier added to the mix?
Japan Drier is a hardener for oil based paints such as Rustoleum. I think this may cut the drying time considerably.
http://www.homedepot.com/buy/paint/cleaners-thinners-removers/klean-strip/1-pint-japan-drier-54686.html
loneagle
Number of posts: 43
Registration date: 2010-12-23
Re: Using Japan drier to reduce tack time
Post by nhmercracer on February 4th 2011, 12:30 pm
I saw this at True Value the other day. Wondered the same myself.
nhmercracer
Number of posts: 103
Registration date: 2010-10-11
Post by loneagle on February 5th 2011, 12:06 pm
I did some research on this. The japan drier works ok. I cuts the drying time quite a bit. An enamel hardener works much better.
I found a hardener at O'Reilley auto parts that is designed for alkyd enamel. This stuff works great with rustoleum and penetrol. I brushed my door jambs with this mix and they came out like they were sprayed.
http://www.autobodymaster.com/product_list.jsp?PHPRJ_GROUP_ID=44078
If O'Reilleys doesn't have it on the shelf. they can order it.
loneagle
Number of posts: 43
