best way to stop water in air line
Post by 78StangII on February 6th 2011, 4:41 pm
Okay, I was out today getting my shop ready to paint the Mustang. One of the things I needed to was to move my water/oil separator further a way from my tank. I also ran my air line up at an angle and down at the other end. The angle I have is to let the condensed vapor/water run back into the tank.
Well, I ran the pressure up but I'm still getting a little water out the other end, though not as bad as before I done this. I was planning on buying a in-line filter to go on the spray gun. Is there anything else I can do to minimize water build up in my air lines? Thank - Kevin
78StangII
Number of posts : 136
Re: best way to stop water in air line
Post by retired plumber on February 6th 2011, 10:30 pm
Did you put a drip leg on the end of your line and have the spray gun line put on a tee at least 12inches above the drip leg? I have run air lines in commercial buildings and that is the way they do it there. Also you need to put a drain valve at the end of the drip leg and drain both it and the compressor before you start. I would put the filter (good idea) at the tee where the line for the gun comes off the drop.
Post by 78StangII on February 7th 2011, 6:02 pm
I've been sitting here think about that. I'll go ahead and add a drip leg in line. Thanks
78StangII
