Wet sanding paint runs.
Rolled On Forums :: Rolled On Forums :: Exterior :: Sanding
Page 1 of 1 • Share •
How long should you wait before you try and wet sand paint runs?
78StangII- Rank
- Number of posts: 136
Job/hobbies: Technical Specialist, muscle cars, Astronomy.
Project: painting a 78 Mustang II Ghia.
Registration date: 2011-02-01
Re: Wet sanding paint runs.
I have found 48 hours to be the shortest time before I can wetsand runs. The paint needs time to harden so you can be more aggressive to get the runs out. Be sure to use a harder foam block. I have actually used my finger with papte alone to get the high spots in the runs. Be very careful.
nhmercracer- Rank
- Number of posts: 103
Registration date: 2010-10-11
Thanks. I have one of those black hard rubber sanding blocks. Would a foam block be better to use?
78StangII- Rank
You could also try a sharp razor blade... works good enough for me!
austin26372- Rank
- Number of posts: 121
Job/hobbies: Ford trucks!
Project: 1990 F-Superduty
Registration date: 2010-11-24
The foam blocks come in a few "hardnesses". I have both a 3M 05530 pad, which is very soft, and a Motor Guard Soft Block SB-1, which has two types of foam sandwiched together. It is harder, and better for getting the paint flat.
You can get them at any paint supply house.
nhmercracer- Rank
Similar topics» Portlaw runs
» All things paint.
» Peugeot Paint Colour Codes
» 1968 Chevy 108 Window (Odd Paint)
» Your automatic watch watch runs to fast how do you slow it down?
» All things paint.
Page 1 of 1
