Do i need to or not?
Post by Raun31 on May 9th 2011, 11:13 pm
I have a 93 mustang that is white and kinda dull and i wanted to paint it with the rustoleum topside white and i was wondering if i should sand all the way down and prime and paint or just sand and repaint since its the same color
Raun31
Registration date : 2011-05-09
Re: Do i need to or not?
Post by retired plumber on May 9th 2011, 11:43 pm
The best undercoat is the factory paint if it is still good. If so, just sand and repaint.
Post by Raun31 on May 9th 2011, 11:47 pm
ok thanks mike another question what all do i need for the painting and i wana use the topside cause its look like a more glossy appearance to it so i also need the ratio to mix
Raun31
Post by retired plumber on May 9th 2011, 11:56 pm
I haven't sprayed that paint but I would think probably about 3 paint to 1 thinner. That is about what regular auto enamel paint is reduced to. You can experiment from there. If you haven't sprayed before a bit of practice using an old fender or something, even a large piece of cardboard, would be nice and you can alter the mix from there if you want.
Post by Raun31 on May 11th 2011, 6:32 pm
ok one more question how would i go by painting my car with the same white just small body damage and which is better rolling or spraying
Raun31
Post by retired plumber on May 11th 2011, 11:56 pm
I have always sprayed because I have the space and can. It is a lot faster and, I think, easier because there is less sanding.. If you just have damage confined to one panel then repair it, mask off the rest of the car and paint away. Make sure the whole car is masked because it you miss an area you WILL get overspray there. The prep is the same wither you roll or spray. another thing is if you even think you can see something in primer you WILL see it in color, however white is pretty forgiving. Good luck
Post by Raun31 on May 12th 2011, 7:11 pm
so do i need to apply a primer to it or just repaint it since its the same color
Raun31
Post by retired plumber on May 12th 2011, 7:45 pm
If you go through the metal you need to primer that. Since you are white it is best to use a light gray or white primer. And yes, a rattle can will work fine for that.
Post by Raun31 on July 31st 2011, 5:08 pm
wat grit sandpaper do i need to use to start spraying the undercoat which is white aslo
Raun31
Post by cac1967 on July 31st 2011, 6:22 pm
I would sand the whole car with 320 or 400,and wipe down with wax and grease remover before shooting any primer or paint.
