Project 1994 F150
Page 2 of 2 Previous  1, 2
Re: Project 1994 F150
Post by way2fasts on June 27th 2011, 1:58 am
Finally done, has a bit of orange peel, surprisingly its about the same as a new f150, yes i did try to get some pictures of it next to a new one at a dealership, unfortunantly they didnt have a tourch red single cabs on the lot, but the one thing i am having trouble with is the masking tape i used to cover all the chrome trim around the door handles windows, has decided not to come off, like there is no way it is stuck on there i tried peeling it off and some areas come off but others its just superglued on and leaves a really bad sticky mess, any ideas of what i can do, and by the way a cutting blade will not work i am dealing with chrome!!
way2fasts
Number of posts : 48
Post by 63Falconconvert on June 27th 2011, 8:23 am
either use a good wax/grease remover or mineral spirits. That should melt the glue. Once the sun/heat melts that glue it's really tough to get off.
Post by dean_af on June 27th 2011, 9:37 am
GooGone should do it.
Post by Tommy Hillbilly on June 27th 2011, 1:47 pm
That looks really good! Especially the reflection off of the hood. It reminds me of a first-gen Lightning. A plastic scraping blade might help, in combination with the above suggestions. I think you can probably get away with using a razor blade if you're careful.
Post by retired plumber on June 27th 2011, 4:38 pm
If you use ANY kind of chemical make sure you protect your new paint or you will be doing part of it over again. Don't ask me how I know, please.
Post by way2fasts on September 6th 2011, 1:48 am
i need some help i finished up my truck a while ago and have been driving it, but i have just found some paint in the lower part of my rear window that i must have nailed, how would you remove this
way2fasts
Post by retired plumber on September 6th 2011, 11:01 pm
A rag and some paint thinner or lacquer thinner CAREFULLY rubbed should take it off or maybe a plastic razor blade. I have even heard about using 0000 steel wool but have NOT tried that so I wouldn't recommend that.
Post by way2fasts on September 26th 2011, 2:59 am
thought i would update it, i have got some of the paint off the windows but not all, but i was able to find a decent set of rims pretty cheap
way2fasts
Post by craigsnedeker on September 27th 2011, 8:43 am
Wow, that looks fantastic! I'm gonna paint my truck like that but have black on the bottom, so the red is like a stripe. and those rims look nice
craigsnedeker
