1979 Cadillac Miller Meteor Fleetwood Hearse
Page 2 of 2 Previous  1, 2
Re: 1979 Cadillac Miller Meteor Fleetwood Hearse
Post by Noah Zarq on July 22nd 2011, 1:45 pm
I used that rust converter back when I worked in a body shop in the early 80s. We bought it in 5 gallon buckets and it smelled like chocolate milk when we sprayed it! The body shop I managed only did tractor trailers, and the ones from up north had to be sandblasted before we did anything and we'd spray the stuff on the frame rails. I also used it on my LTD and Dodge pickup. It goes by several names. Dries rock hard and works.
Post by azmyth on August 5th 2011, 8:31 am
so.. what was that adhesive called that supposedly bonds metal?
also, for small little areas I need to smooth out in a crease, where there's scratches and pinholes.. is it best to fill those with bondo.. or something else?
azmyth
Number of posts : 23
Registration date : 2011-06-26
Post by azmyth on August 17th 2011, 8:20 pm
I got the first coat of paint on her today. Rustoleum gloss white..
how often do you sand? and do you wetsand or? I'm about to be on my 2nd coat, it seems hard to cover up the grayish primer with the paint so thin lol.
azmyth
Post by azmyth on August 17th 2011, 8:25 pm
Here's a few pics. I had the entire thing masked, but i knew it was gonna be a few days before i got to do another coat, and I was afraid i'd be cleaning up a mushy newspaper mess.
azmyth
Post by 86 stang on August 17th 2011, 11:08 pm
if ya got two coats on then its time to sand ya its thin at this point but it will cover what ya want now is to get it flat and smooth /start with a higher grit and only go down a grit if you have to popcorn
Post by azmyth on September 8th 2011, 9:20 pm
is the sanding just to smooth the orange peel and runs? or is it to make it shine?
azmyth
Post by cac1967 on September 8th 2011, 9:29 pm
The sanding between coat's smooth's the op,you progress to higher grit's as you get closer to you last coat, then sand with 1200 to 3000 grit before you buff to get the shine. Very Happy
Post by azmyth on September 8th 2011, 9:55 pm
hmm I haven't had to sand very much, i didn't cut much orange peel at all.
azmyth
Post by azmyth on September 9th 2011, 8:25 am
more questions..
Whats the best way to Buff the car? Can it be done by hand? I don't have a buffer. Also, for the red trim.. is it better to brush it on with a foam brush, or rattle can it?
azmyth
Post by Tommy Hillbilly on September 9th 2011, 2:33 pm
azmyth wrote:more questions..
Yes, but hoooo-doggy!!! A whole car? YOUR car? My guess is that you would end up with carpal tunnel syndrome or arthritis or something. I once did a pair of doors, and used to think that my cheap *** would do a whole car by hand, but not any more. I'd cobble something together with a drill before I'd do it by hand.
Post by Noah Zarq on September 9th 2011, 2:40 pm
I have done it by hand, but I was 17 and had too much energy. No reason to do it by hand, especially on a mammoth vehicle like yours. Get a good buffer. It'll pay for itself in medical bills later.
Post by retired plumber on September 9th 2011, 10:43 pm
Go get a harbor freight special for $29.99. Your body WILL thank you plus you will use it for lots of other things you don't know about yet. Laughing
Post by 86 stang on September 9th 2011, 11:17 pm
i would use a roller for your trim if you can/ you can always try to use the foam brush and then go back over with a smaller roller// as for the rattle can /you take the chance of getting red on the rest of the car/un less your willing to mask off with paper /tape /and that call pull off spots of paint if not dry
Post by azmyth on September 11th 2011, 8:12 am
Used some good masking tape, not "masking tape" but the kind specifically for this kind of thing. I sticks but not hard enough to pull paint off.
azmyth
Post by 86 stang on September 12th 2011, 6:06 pm
almost there thumbs up
Post by azmyth on September 12th 2011, 6:17 pm
So yeah, after Halloween.. I'm going to get some help with fixing my shoddy body work. I wanted to be able to cruise around on Halloween in this thing so I had to draw the line somewhere. Good thing I went with a rusto paint job as its easily repainted!
azmyth
Post by azmyth on September 13th 2011, 8:29 pm
So the stripes look better in the picture than they do in person..
I couldn't figure out how to get the trim off.. so I masked it.. well.. it had been masked since I rolled the white, so it was on there pretty good and it didn't want to come off without a fight.. so the edge where the trim is isn't too great. I used the rattle can gloss red.. and I would like to touch it up with a brush.. is there a small can I can buy to use with a brush? and what color would match?
azmyth
Post by Tommy Hillbilly on September 13th 2011, 11:00 pm
Just get whatever red paint, and redo the stripe.
Post by retired plumber on September 13th 2011, 11:24 pm
Rattle can and bulk is the same.
Post by 86 stang on September 15th 2011, 3:29 am
ya i would just go over it one more time
Post by azmyth on September 23rd 2011, 10:23 am
Ok, one last question..
I drilled holes for my light bars.. as can be seen here..
http://www.youtube.com/watch?v=uIQ8RbAyDmc&feature=player_embedded
and I think somehow I didn't wipe all the "metal bits" that the drill flew everywhere.. so now I have all these tiny brown spots on my hood, where I guess the metal bits have rusted.. grrr..
can I just lightly sand those spots down and repaint right there?
azmyth
Post by cac1967 on September 23rd 2011, 7:11 pm
Try using a good cleaner wax like megquire's cleaner wax on those spot's.
Post by azmyth on November 10th 2011, 8:07 pm
hey guys.. so its been a while..
here's how she looks now!
and while i've gotcha, we are entered into a costume contest. I'm trying to win my 4 year old (the staypuft marshmallow man) a replica ghost trap from the movie. We are about 15 votes from taking the lead. I'd appreciate it if you guys could go to this link and "like" the picture of my family in front of my car.
http://www.facebook.com/photo.php?fbid=270024116374672&set=a.270023849708032.64641.112118442165241&type=1&ref=nf
azmyth
