wet sanding how to?
wet sanding how to?
Post by jonathand on June 29th 2011, 5:11 pm
wet sanding it's kinda confused me... like how much pressure?,how long should i do it for,Should i use a diffrent type of sandpaper?
any techniques i should know?
jonathand
Registration date : 2011-06-25
Re: wet sanding how to?
Post by cac1967 on June 29th 2011, 7:54 pm
When wet sanding you use only light pressure,you sand until you have a uniform flat or satin look to the paint, make sure you keep the surface wet at all times, sand until all the orange peel is gone,and you only use wet /dry sand paper,I would wet sand in between every two coat's, start with 600 grit and work your way up too 2000 grit on the final coat if using a gloss paint before you buff. I've painted many of my own car's and some for my friend's, and I've found out the better the wet sand you do,the better the job look's when you buff. Hope this shed's some light on your question.
Post by 63Falconconvert on June 29th 2011, 10:00 pm
check out this video. Pete is a little rough around the edges but it's a good video
http://www.youtube.com/watch?v=mM3sFQd0KXk
