My 1965 C-10 Shop Truck: "Faux-tina Paint or Bust"
Page 4 of 5 Previous  1, 2, 3, 4, 5  Next
Re: My 1965 C-10 Shop Truck: "Faux-tina Paint or Bust"
Post by Tommy Hillbilly on February 9th 2013, 6:19 am
I don't hate it, but I wouldn't do the rear fenders - unless that's how GM did it back then. Just my opinion...
Post by 63Falconconvert on February 23rd 2013, 1:03 pm
I like the trim says the man with a luggage rack on the back of his 63 Falcon.... geek
Number of posts : 1261
Post by Lakeroadster on February 28th 2013, 8:10 am
Tommy Hillbilly wrote:I don't hate it, but I wouldn't do the rear fenders - unless that's how GM did it back then. Just my opinion...
No trim on General Motors step side fenders from the factory on 60-66's... and that's kind of the point of me adding the trim. Why would GM put trim on the doghouse and not on the bed, just looks half a $ $ e d IMHO What a Face
Lakeroadster
Number of posts : 62
Project : 1965 Chevy Pickup SWB SS
Registration date : 2010-09-09
Post by 63Falconconvert on February 28th 2013, 8:51 pm
trim will be the least of your worries after all of the purests, gold chainer street rodders, and other posers see your truck and learn your paint method affraid yea yea
Post by cac1967 on March 9th 2013, 10:15 pm
I like the trim!!! go for it!!!!!
Post by Lakeroadster on May 12th 2013, 9:14 pm
Did a road trip in the ole orange crate today now that its pretty much road worthy :rolleyes:. First time its been out on the open road for about 5 years. Time flies when your having fun.
We took our GPS to confirm the speedometer is accurate, which it was to my surprise. I would have figured the huge rear tires would have thrown it off a bit. All in all a good first outing.
Gearing and tires produce 2000 RPM at 50 MPH in 4th gear. Which is pretty much what I had figured.
Lakeroadster
Post by Tommy Hillbilly on May 12th 2013, 10:07 pm
That's what it's all about. Like the little noose on the inside mirror...
Post by HD_Jeep on May 18th 2013, 10:49 am
Nice job. I use to have a 63 step side and a SWB ones years age. I would love to find another some day.
HD_Jeep
Number of posts : 24
Job/hobbies : Graphic Artist, Jeeps, Harleys, Photography
Project : 91 Jeep Grand Wagoneer FSJ
Registration date : 2010-12-05
Post by 63Falconconvert on May 29th 2013, 9:56 pm
SWEET!!!!!!!
Post by tbirdsps on June 12th 2013, 1:54 pm
I was thinking of doing that to my truck but in the reverse.  Applying the primer over the paint and sanding to achieve a similar look.  Thoughts?
Post by Lakeroadster on June 12th 2013, 7:49 pm
tbirdsps wrote:I was thinking of doing that to my truck but in the reverse.  Applying the primer over the paint and sanding to achieve a similar look.  Thoughts?
If you mean roller application of primer over an existing smooth paint, and then sanding, I don't think that will work.
The faux patina system works because the primer is applied first with a heavy nap roller to give it a bunch of texture, then the color goes on after the primer.  When you sand it, you sand through the colored high spots, exposing the primer, while the color in the low spot also remains.
Rough coat first, then smooth coat.
Last edited by Lakeroadster on June 12th 2013, 8:12 pm; edited 3 times in total (Reason for editing : Trying to Clarify.....)
Lakeroadster
Post by Lakeroadster on June 12th 2013, 8:04 pm
It should be OK, but if it were me, I'd maybe want some clear over it.
I saw this truck on another site and wanted to throw the photos up here.  The matte finish clear just doesn't look correct, IMO.  And when the clear starts to separate from the paint from being sunburnt it will look even more "non-patina".
No Clear
With Matte Clear
No Clear
With Matte Clear
Lakeroadster
Some Updates On The Ole Orange Crate
Post by Lakeroadster on March 25th 2014, 8:54 am
Rear Spring Re-Deux
I used 5" drop springs on my truck.  The ride was like a big ole Buick and the springs were so light weight that hauling anything of significant weight in my truck wasn't possible.
I replaced the rear springs with 4" drop Heavy Duty Springs.  Much better ride and I like the added rake, looks a little more like a work truck, IMO.  Keep in mind it's only an inch different in rear height.  But since they are heavy duty I can now haul more than just a couple hundred pounds of stuff :DThe new springs look very similar to the OEM springs that were originally on the truck, just a couple less coils and shorter overall height.
4" Heavy Duty Drop Springs are on the left, CPP P/N 603-4HD, 5" Drop Springs are on the right, CPP P/N 603-5
Before.....
After....
Custom dash mat.
There's a local place close to us that makes custom dash mats.  The gal there said if I made them a template they could make a mat for my '65 that has the '67 Camaro dash in it.
Easy install, Velcro across the front, gravity does the rest.
Lakeroadster
Post by 63Falconconvert on April 18th 2014, 1:59 pm
that looks awesome. The Camaro dash is a very nice touch
Post by cac1967 on April 20th 2014, 11:55 pm
Lookin good, love the Camaro dash too!!!!!
Post by Tommy Hillbilly on April 24th 2014, 5:49 pm
I thought I noticed the Camaro dash - but then thought "well maybe GM just used that dash in trucks..." That does look cool.
Post by LARRYBOMB on May 3rd 2014, 1:33 am
My Ranger's natural look. I will be painting it this summer.
LARRYBOMB
Number of posts : 23
Bed Step No Slip Paint May 2014
Post by Lakeroadster on May 15th 2014, 7:06 pm
Tommy Hillbilly wrote:I thought I noticed the Camaro dash - but then thought "well maybe GM just used that dash in trucks..." That does look cool.
That's the look I was after, as if it came that way from the factory.  thumbs up
I painted the ribs on the bed steps today with Rustoleum Undercoating.  I used this on the step bumper on my daily driver and it works very well.
Also drug my early 70's Sears / Roper Mini Bike out of the rafters.   Restoring it is on my short list of upcoming projects.
Lakeroadster
May 2014: Painting "Chevrolet" On The Grill
Post by Lakeroadster on May 31st 2014, 3:25 pm
I know there are vinyl letters available, but I prefer paint, so here's how I made my own masking template to paint the CHEVROLET letters on the grill of the ole Orange Crate.
Using blue painters tape, the CAD letters I created and clear shipping tape I cut out each individual letter
I then cut out the letters using an X-Acto knife
I attached each template onto each letter
Then it was a simple matter to mask around the templates and spray paint the letters
Ain't she pretty :o
Lakeroadster
Post by Tommy Hillbilly on June 7th 2014, 10:52 pm
Looks good!
Post by 63Falconconvert on June 9th 2014, 9:03 pm
Looks like your mini bike has a little front end damage.....I'm guessing a tree????
Post by Lakeroadster on June 13th 2014, 8:37 pm
63Falconconvert wrote:Looks like your mini bike has a little front end damage.....I'm guessing a tree????
It does indeed have front end damage... I'll be fixing that.
Nope, no trees.   Ramp jumping... I blame this guy:
Lakeroadster
Post by Tommy Hillbilly on June 21st 2014, 12:59 am
I didn't notice before, but LOL'ing at the blueprint used as masking... agree
Frugality... kinda rare these days.
Post by Lakeroadster on August 19th 2014, 7:12 pm
Well Tommy I made my living as an Engineer and kept a lot of the old void drawings to use for just this type of stuff.
Lakeroadster
McGraw's Chevrolet Service Truck
Post by Lakeroadster on August 19th 2014, 7:40 pm
Here's a concept sketch of lettering for my truck. McGraw's Chevrolet was the local Chevy dealer where my dad bought his '67 Impala SS.  the lettering would be "distressed", looks too crisp below.
What do ya think, Yeah or Nay?
Lakeroadster
