1986 Camaro Iroc Hood
Post by 86Iroc on December 27th 2007, 5:07 pm
Ive been working on the hood for a little and its almost done... I think.
I need some help and opinions though:
When wet sanding I'm trying to get it smooth, and get rid of all the shinny parts right?
Below is a picture after wet sanding the 6th coat with 1000 grit. I'm not really even applying any pressure, just sliding the sanding block. Am I wet sanding it correctly? Is it suppose to look like this? Do I need to wet sand the shinny parts to make it look like the rest of the hood?
(All the little white specks you see are from the towel, I just got done drying it.)
Now when I wet sand my final coat with 2000, is it suppose to look something like that, and then just buff out? As you can probably tell from all the questions I'm nervous about if I'm doing this right.
86Iroc
Number of posts: 7
Job/hobbies: Student
Project: 86 Camaro Iroc-Z
Registration date: 2007-12-20
Re: 1986 Camaro Iroc Hood
Post by karlbasher on December 27th 2007, 7:08 pm
from what i have heard you are suppose to put on your last coat and not wetsand it just buff it ask matt though he will be able to answer this easily but i think you should do another coat and then buff it out
karlbasher
Number of posts: 83
Registration date: 2007-12-24
Post by tzyoung on December 27th 2007, 7:11 pm
From what I can tell by the pictures your wet sanding looks great. Ideally you want all of the shiny spots gone. It looks like you have shiny lines instead. I think if you went ahead and buffed what you have it will turn out awesome. I have tried to buff out paint that looked worse than what you have here and it turned out fine. It's looking good. Make sure to post pictures of it when its all buffed out.
-Trent
tzyoung
Number of posts: 60
Job/hobbies: engineering student/Cars and RC planes
Project: 89 Camaro, 89 Honda Accord
Registration date: 2007-12-09
Post by Matt on December 28th 2007, 3:30 am
I agree with tzyoung. It's looking good so far and your technique seems to be working well. When you wetsand your not trying to remove the paint, you are leveling everything out to make it uniform. As far as the shiny areas, yes wetsand them until its all the same. The entire area should look dull but will feel as smooth as glass. Don't worry about it, a high revolution buffer will bring your shine right back out where it needs to be. By the way, I'm loving the white and black Camaros in the background. thumbs up
:: Matt, Administrator
Number of posts: 563
Project: Ford Ranger Splash
Registration date: 2007-12-08
Post by 86Iroc on December 28th 2007, 5:25 pm
Thanks for the info guys Very Happy
I wet sanded some more this morning and started to polish it. Its coming along nicely I think. I'm using a Porter Cable, and Menzerna Intensive Polish pictured below. In some of the pictures its hard to see, but you can see some of the dullness/sanding lines, or something? As I continue to polish it out with this, all this will disappear like you mentioned correct? Is there a different swirl and scratch remover that I should be using?
(as you can tell from the pics I haven't done the middle, or where the louvers sit yet.)
Matt wrote:By the way, I'm loving the white and black Camaros in the background. thumbs up
Thanks Cool. My dads got the white 92 Z-28, My bros is the black 83Z behind my Iroc (under the car cover), and my mom has the Black 92 RS behind the white one. Yeah you could say we love Camaros ha ha
86Iroc
Number of posts: 7
Post by tzyoung on December 28th 2007, 7:13 pm
That's looking great so far. If you are having trouble with micro scratches in your finish. (They make everything look hazy) Then you might want to try a good swirl remover and then use your polish. The swirl remover is kinda of like using a little coarser grit to take out sanding scratches.
I'm no expert at detailing, but I personally think that you will get the results you want by keeping at it with that polish.
Keep up the good work
tzyoung
Number of posts: 60
Post by badbyrdkoncepts on December 28th 2007, 8:48 pm
WOW don't know what else to say
applaude great job
keep on rock J
badbyrdkoncepts
Number of posts: 109
Registration date: 2007-12-18
Post by John617 on December 28th 2007, 10:57 pm
Wow, kudos! I only wish my car will come out looking like yours. What paint are you using? I'm using Gloss Black Rust-o-leum.
John617
Number of posts: 5
Project: 03 Ford Crown Victoria
Registration date: 2007-12-19
Post by Matt on December 29th 2007, 1:17 am
That's one slick paint finish. Looking good man keep doing what your doing, your definately on the right track!
Post by 86Iroc on December 29th 2007, 8:45 pm
Thanks everyone for all the compliments.
John617 wrote:Wow, kudos! I only wish my car will come out looking like yours. What paint are you using? I'm using Gloss Black Rust-o-leum.
Thats what I used.
I'll get some better pics when the weather clears up, probably wont be till Monday or Tuesday. So till then, everyone have a safe and happy New Years. hit it
86Iroc
Number of posts: 7
Post by Matt on December 29th 2007, 8:55 pm
I want an Iroc Sad
Post by 94honda on January 2nd 2008, 2:55 pm
DANG..yall do like Camaro's...all nice,polished...i have chill bumps!!! applaude
94honda
Number of posts: 6
Job/hobbies: Student..PoliScience Major
Registration date: 2008-01-01
Post by Matt on January 15th 2008, 12:05 pm
Would you be interested in selling any of those Camaros hey
