Rust question
Rust question
Post by skirk on August 16th 2011, 9:02 am
i am working on a 66 chevy, plan on rolling it with rustoleum in a few weeks. areas that i have sanded and prepared, i sprayed with rustoleum automotive primer, looks good but there are places where there was some light rust. i sanded it down to metal prior to spraying primer. now after a couple months, there is some rust starting to show on the surface of the primer again. what is causing this and how to fix. can i just wipe the primer surface with something like "CLR" or something prior to rolling?
thanks
skirk
Registration date : 2009-09-14
Re: Rust question
Post by retired plumber on August 16th 2011, 11:09 pm
Regular primer is NOT waterproof so rust will come back. You need to sand the rust away again and, if it will be a while before you actually paint, put primer/sealer on it.
Re: Rust question
Post by 63Falconconvert on August 17th 2011, 8:46 am
Primer is like a sponge, it will hold water & moisture. Rusto makes a good rust reformer http://www.rustoleum.com/CBGProduct.asp?pid=363 whipe your bare metal with that, let dry, top coat with primer, and try to get some paint on it within a weeks time if you're driving your car in the rain or if the primer is getting wet. Or like Mike suggested, seal it.
Re: Rust question
