spraying tomorrow
spraying tomorrow
Post by hard attack on August 17th 2011, 1:59 am
Spraying my 91 dodge stealth TT gloss black tomorrow. The maaco paint job it had was ***.
I will be thinning it with acetone. Can anyone give me ANY tips on spraying with acetone? (mixing, dry time...etc)
I plan on
Mixing 10-15% acetone
Spraying on 3 or 4 coats waiting for it to tack up between coats.
I do have mineral spirits, but i start school on the 18th and I dont have time to mess with the drying process of that. Plus I KNOW my clumsy *** will mess it up somehow.
hard attack
Registration date : 2011-08-15
Re: spraying tomorrow
Post by 63Falconconvert on August 17th 2011, 8:50 am
I never used acetone but if it was me and I was spraying I would use enamel reducer and a enamel hardener. Your paint will dry rock hard in a day.
Post by hard attack on August 17th 2011, 12:55 pm
i couldn't find enamel hardener anywhere. Sad I guess I'll order it online for next time i paint
hard attack
Post by 63Falconconvert on August 17th 2011, 1:30 pm
do you have a tractor supply by you? You can use there valspar tractor paint hardener
Post by cac1967 on August 18th 2011, 5:57 pm
The acetone will dry fast, I would mix about 4 oz ms with your paint acetone mixture. I used a mixture of 8 oz rusto 4oz ms 4 oz acetone to paint the door jambs on my 87 ranger, worked really great!!dryed in about an hour. You could adjust this mixture to suite your need's.As 63falconvert said get the valspar hardner for oil based paint's!!
