1971 Camaro
Page 1 of 1 • Share •
1971 Camaro
All, my Camaro needs to go ASAP. I just can't keep it any longer. Too many project, too many kids. It needs to go to someone that can finish it and enjoy it. Here's a list of all it has, and it has some serious stuff on it. it's not far off from being something you can drive and continue to fix up. I love this car, but it's time with me has passed. I can email additional pics out. If you search in the project section you can find pics of the car. I'm asking $9900, but the price is negotiable.
I hope to someday use the methods I keep reading about here. I love it. Anyway, here's the info about the Camaro.
1971 Camaro
Originally a 350 2bbl/Turbo350 car with a 3.08 posi.
Current engine is a stock 454 long block and a Turbo 400 trans from a truck. 2 bolt main. Engine is extremely clean with very low miles. It has:
- Rebuilt Heads
- New head gaskets
- Edelbrock Torker Intake
- Holley 3310 750 cfm carb
- Hooker Super Comp Headers
- Brand New Chrome 7 Qt Oil Pan
- New Sealed Power pushrods
- New Distributor with Accel parts and wires
- Brand New Melling Oil Pump
- Brand New Moroso Oil Pickup
- New hoses, new thermostat, new Flexalite fan
Chassis and Other Accesories
- Rear is a Big End Ford 9" narrowed 3" per side. Nodular Center Section, Detroit Locker, Richmond 4.30 gears, Moser 31 spline axles, Wildwood Dynalite Disc Brakes and long screw in studs.
- Body is Mini-tubbed and has 15x12 Weld Pro Stars with 29.5x15 MT Sportsman Pros. Tires fit with plenty of room. 15x3.5 Pro Stars for the front with Mickey Thompson Sportsman skinny's.
- 16 Gallon RCI Fuel Cell inside trunk
- Holley Electric Pump
- All new 3/8" hard and braided fuel lines
- Mallory Fuel Regulator
- Auto Meter Sport Comp Fuel Pressure gauge runs the isolator so the gauge in inside the car (It works 100% and is accurate), there is also another liquid filled fuel pressure gauge under the hood
- Autometer Sport Comp gauges. Tach with shift light and Dial Back, Water, Oil, Vacuum and Temp gauges mounted inside the car in the center dash A/C vent for easy viewing
- 8pt Roll Cage from S&W Race Cars. Have a swing-out bar kit for driver's side but not installed
- Rear frame rails and subframe connectors from S&W Race Cars
- Grant 969 Steering wheel and a tilt steering column
- 3" Fiberglass Cowl Hood w/ Low Tension Springs
- New Body Bushings from Energy Suspension
- 4 Core Radiator
- Automatic Console with shifter from a 73 model
- Additional Leaf Spring pads from Energy Suspension
- Have brackets for Front inner fenders (they were removed a long time ago).
I have over $7000 in receipts for the parts.
Body, Interior and overall condition:
Currently the car is white. The car needs bodywork which I'm in the middle of doing right now. It's more of a drag car/driver than anything else. I have some patch panels for the bad areas (rocker panels and rear ¼'s in front of the tire). The Black interior is 75% there and in OK shape for driving and drag racing. The carpet is crap. The seats are in OK shape. A few small tears here and there, but overall not bad. They are still comfortable to sit on, and I'm a fairly big guy (6' 275lbs). Inside the car I've POR-15'd the entire interior already, as well as the trunk which is totally done as seen in the pic below before the fuel cell, battery and fuel pump were installed. My next move was to clean the underside and POR-15 that as well.
The car sits like an old 70's Pro Stock car in my opinion with the wide tires in the rear, which was my intention when I first started building. It goes down the road real nice and straight and handles fairly well. I had it on the road as late as May 2010 before the 350 spun a bearing and had zero oil pressure. At that point I pulled the 350/T350 and sold it. Since then the engine bay has been totally cleaned (all dirt, grime sludge removed) and recently painted. The car has a lot of good parts on it. It's just a car you can have fun with. It needs more, but it's not far from being a cool car.
Here's a quick video of the car before the 350 went south in May 2010:
http://www.youtube.com/watch?v=ZC-McGErtLo
1971 Camaro
- Rebuilt Heads
- New head gaskets
- 4 Core Radiator
petieg383- Rank
- Number of posts: 5
Project: 1971 Camaro
Registration date: 2010-05-13
Similar topics» 1971 Camaro
» "How To" Install Sound Deadener in a 70-81 Camaro or Trans Am
» 67 Camaro - Black on Black
» 2002 Camaro SS 35th Anniversary LE
» Camaro SS hood
» Camaro SS hood
Page 1 of 1
