'63 VW Bug, Gloss black
Page 2 of 2 Previous  1, 2
Re: '63 VW Bug, Gloss black
Post by 63Falconconvert on January 11th 2012, 1:40 pm
cac1967 wrote:Appears to be sanded through to another layer of paint, this is what appear's when you sand through clear on bc/cc. go up a few grit's on your paper and buff with uc then buff with the ult polish. If it does not come out just sand with 600 and repaint. Just my 2 cents
Thats exactlly what happened. I did that alot on the 63 but being it's white you don't notice it as much.
Post by subgraphic on January 11th 2012, 2:22 pm
Here is the wagner I will be using
Thanks for the help everyone. I sanded until the paper wasn't "cutting" any more, plus some. I suppose it was to much.I think that when I spray it, I'll go thicker, and prolly spray 3-4 times so I have enough to sand.
I will be using Rusto satin black on the top, and gloss on the sides, exactly like this bug:
subgraphic
Number of posts : 19
Registration date : 2011-11-06
Post by 63Falconconvert on January 11th 2012, 2:25 pm
wow that bug is bag @ss for sure. Is it bagged or hydros?
Post by subgraphic on January 11th 2012, 2:26 pm
leeready wrote:Which wagner do you have? I have this one: http://www.homedepot.com/buy/paint/paint-sprayers/wagner/control-spray-double-duty-93373.html
I only sprayed the hood on my last project. It came out good.
would love to see some pics!
subgraphic
Post by subgraphic on January 11th 2012, 2:28 pm
63Falconconvert wrote:wow that bug is bag @ss for sure. Is it bagged or hydros?
All bags on bugs now-a-days. They actually ride nice when its set up right. Ive considered it... Cool
subgraphic
Post by 63Falconconvert on January 11th 2012, 2:30 pm
I love bugs/dune buggies. My next project is going to be an early 60's buggy.
Go for the bags....what kind of cash is needed to do it right?
Post by subgraphic on January 11th 2012, 2:41 pm
Figure 1500-1800 for the full kit, another 200 or so for the miscellaneous stuff.
Takes a bit of welding. If the bug is down to the pan, you can prolly have it all installed for 25 hundred.
http://airkewld.com/index.php?option=com_virtuemart&page=shop.browse&category_id=88&Itemid=252
subgraphic
Post by 63Falconconvert on January 11th 2012, 2:50 pm
How's the ride once it's bagged?
Post by subgraphic on February 18th 2012, 2:32 pm
Well, I took a shot and sprayed the hood with my wagner, using ACE hardware satin black rust stop paint.
The can say it didn't recommenced thinning it, so I didnt.
Here are the results:
So, it looks like it was sprayed with bedliner. The wagner spit and wasn't as smooth as I had hoped, but I was trying to limit over spray so I didn't test it as much as I should have.
The good news is that I really like the satin color, and I'll move forward with this on the top and do the gloss black, wetsanded cut and polished on the sides.
next steps: sand hood back down to flat, thin the paint, test the gun until It sprays smooth, pray to god, re-shoot.
Any tips or advise for shooting satin? I cant sand it once its shot, can I? Will thinning it help? Should I roll it instead? Cool
subgraphic
Post by subgraphic on February 18th 2012, 2:37 pm
Also picked up some Porsche 911 seats...
yay!
subgraphic
Post by cac1967 on February 18th 2012, 7:02 pm
Thinning should cure the peel and maybe a little penetrol would help it flow better.
Post by T.Hadley on February 18th 2012, 10:17 pm
cac1967 wrote:Thinning should cure the peel and maybe a little penetrol would help it flow better.
X2 Cool
Post by Gore on February 19th 2012, 11:48 am
I sprayed some toolboxes with satin black and eventually got it to turn out smooth. I used penetrol, acetone, and japan drier, each in the recommended amounts.
I think the key to getting satin to turn out nice was light coats. If I rushed and put it on too heavy or recoated too soon it would turn out blotchy or too shiny.
Gore
Registration date : 2011-07-02
Post by retired plumber on February 19th 2012, 4:20 pm
I would reduce it about 3 paint to 1 thinner (auto paint style) and go from there. One tack (light) coat, 3 wet coats and a final just misted on coat of mostly reducer with a bit of color in it (with tack time between them of course). This final coat (THEY say) helps to prevent orange peel and from my experience seems to work good.
Post by Noah Zarq on February 19th 2012, 6:42 pm
Gore wrote:I think the key to getting satin to turn out nice was light coats. If I rushed and put it on too heavy or recoated too soon it would turn out blotchy or too shiny.
Absolutely true! When I sprayed Justin's Sentra, I just made several thin coats and allowed it to "flash" between coats. No dry spray, no runs, turned out nice. Of course, it was not rusto/mineral spirits either, but "real" paint and hardner. But the same technique applies regardless of the paint being sprayed.
