Wrinkles in my paint, how do I get rid of them.
Post by jwrape on December 7th 2011, 2:29 pm
Ok, I am spraying the hood of my 86 Fiero GT (Fiberglass). I bought another hood to paint and then swap on.
It was originally red. I sanded and cleaned with Acetone the hood and sprayed it perfectly.
Then, like a dummy, I went to buff it after wet sanding it. I burnt the paint. I should have waited.
Anyway, I got to fill the burn with a little Rustoleum Etched Primer. The primer wrickled up. I sanded it off, cleaned it again with Acetone and then tried again. Wrinckled again.
I sanded it and got all the paint off the hood back to the Red color. Clean sleight, I thought.
So I got it all smooth and cleaned with Acetone again and paint with straight Black Rustoleum again. It wrickles again.
What am I ding wrong, what is on this hood? It's only in the spot where I primed the hood. It seems to have something on it that Acetone won't take off.
I have bought some Den. Alcohol to try after it done drying and I sand it back down again, but I am getting tired of trying over and over without getting to good results I did the first time.
Help me get this thing clean.....
jwrape
Number of posts : 22
Registration date : 2011-06-16
Re: Wrinkles in my paint, how do I get rid of them.
Post by cac1967 on December 7th 2011, 5:55 pm
we really need a pic of the affected area,If it's wrinkling you may be painting over a cheap enamel respray such as what maaco uses, I would like to see a pic of this area, I'm 100% sure we can figure this out!!with all the knowledge on this forum. ahhh
Post by jwrape on December 10th 2011, 3:19 pm
cac1967 wrote:we really need a pic of the affected area,If it's wrinkling you may be painting over a cheap enamel respray such as what maaco uses, I would like to see a pic of this area, I'm 100% sure we can figure this out!!with all the knowledge on this forum. ahhh
Here is a video of what happened and an explaination
http://youtu.be/6jkmQvPD7lE
jwrape
Post by cac1967 on December 10th 2011, 6:41 pm
After watching the video, are you spraying this hood with rusto oil base or using the spray can? if this hood has a cheap enamel respray and you are using a laqur based paint like the primer is, it appear's the paint below it is not dryed or the laquer is pulling the enamel up thus the wrinkling, this is a common problem with laquer based paint on top of a cheap enamel( what maaco uses)laquer is a very aggressive chemical it actually bite's into the surface acrylic enamel and synthetic enamel form's a chemical bond with surface, hope this help's thumbs up
Post by jwrape on December 12th 2011, 10:52 am
cac1967 wrote:After watching the video, are you spraying this hood with rusto oil base or using the spray can? if this hood has a cheap enamel respray and you are using a laqur based paint like the primer is, it appear's the paint below it is not dryed or the laquer is pulling the enamel up thus the wrinkling, this is a common problem with laquer based paint on top of a cheap enamel( what maaco uses)laquer is a very aggressive chemical it actually bite's into the surface acrylic enamel and synthetic enamel form's a chemical bond with surface, hope this help's thumbs up
Does this mean that the Rustoleum Spray Can paint is NOT oil based? I thought it was, i thought the oil base is what fights off the starting of Rust, etc...?
If I understand correctly, I should buy a can of roll on Rustoleum and paint it with a roller like everyone else?
I love the spray, it came out SO beautiful on the fender and the hood at first. It suck that it's not working.
Please verify for me and if I need to change I will I suppose. I have already started this monster project and want to get it done by January if possible. :-)
I guess I would have to go with the roll on paint all over since I know the rest of my car has a Maaco or some sort of paint on it. That's why I am repainting.
Here is my car now, the hood and fender I painted were extras I was working on before dismantling the body.
jwrape
Post by jwrape on December 12th 2011, 5:21 pm
Rolled it today
http://youtu.be/oO15XCb86W4
better, much better
jwrape
Post by cac1967 on December 12th 2011, 9:10 pm
When that dries, wetsand with 400 to get the op out,then thin 50/50 with mineral spirit's roll two more thin coat's , wetsand with 600, then roll two more thin coat's let dry then wet sand with 600, do thi procedure till about 8 coat's , water sanding every two coat's till you reach about 1500 with wet sanding,then buff it the result's will be amazing,look's 100 percent better, glad we could help , if you have any more question's feel free to ask away thumbs up MAN THAT FIERO LOOK'S GREAT!!!!!
Post by jwrape on December 13th 2011, 7:14 am
Awesome Thanks for your help. I appreciate it!
jwrape
Post by retired plumber on December 13th 2011, 7:09 pm
Acetone is like lacquer. It is a very hot paint. It will lift anything enamel that is not OEM or baked. I wiped down a couple of cars with lacquer and then sprayed enamel. I ended up having to sand it ALL off and start over. Good luck.
Post by jwrape on December 14th 2011, 12:30 pm
retired plumber wrote:Acetone is like lacquer. It is a very hot paint. It will lift anything enamel that is not OEM or baked. I wiped down a couple of cars with lacquer and then sprayed enamel. I ended up having to sand it ALL off and start over. Good luck.
Yea, from here on out I will be using Denatured Alcohol for cleaning now.
jwrape
Post by jwrape on December 19th 2011, 12:16 pm
Well the Wrinkles came back again. I have no idea what to do at this point. I have painted and sanded this a dozen times now to no avail
jwrape
